Help my son cranked the jack too high
jrooney
Reg. Aug 2013
Posted 2013-08-13 10:45 AM (#153984)
Subject: Help my son cranked the jack too high
My son was being helpful and when we parked last night he cranked the jack too high and now we can't unhook? Any suggestions?
trot-on
Reg. Dec 2009
Posted 2013-08-13 10:50 AM (#153985 - in reply to #153984)
Subject: RE: Help my son cranked the jack too high
Is the jack stuck? Assume gooseneck, (but never assume). So, still hitched and it lifted the truck?
jrooney
Reg. Aug 2013
Posted 2013-08-13 11:14 AM (#153986 - in reply to #153984)
It is actually the crank that is stuck
jrooney
Reg. Aug 2013
Posted 2013-08-13 11:23 AM (#153987 - in reply to #153984)
Thanks for answering. I am not with them but here is the description:Cranked to the top and won't crank down. I am calling the "jack" the leg that the trailer rests on the ground.Thanks for the help. Yes it is a gooseneck
trot-on
Reg. Dec 2009
Posted 2013-08-13 11:32 AM (#153988 - in reply to #153984)
I'm sure that we have some on here who might be better educated on this, but my guess is that you may need to figure how to relieve the weight/pressure on the jack to get it to release back down past that top notch. maybe with some sort of floor jack. But I'm just not sure....
Posted 2013-08-13 7:17 PM (#153992 - in reply to #153984)
Originally written by jrooney on 2013-08-13 10:45 AMMy son was being helpful and when we parked last night he cranked the jack too high and now we can't unhook? Any suggestions?
If you live on a farm do you have a tractor that is big enough to lift the gooseneck...thereby taking the pressure off the jack? http://www.northerntool.com/shop/tools/product_987783_987783
Edited by PaulChristenson 2013-08-13 7:19 PM
Posted 2013-08-13 7:37 PM (#153993 - in reply to #153984)
I lift my trailer tongues with the FEL bucket all the time when mowing... Tractor loader needs to be able to lift 3500 to 4000# or better.
Bhill
Reg. May 2013
Posted 2013-08-14 7:16 AM (#153994 - in reply to #153984)
Recently the front of my trailer found a ditch that been backfilled and compacted 7 months ago. The jack pad sunk around 18 inch's in to the abyss. I used a floor jack rated at 6000 lbs and 36 inch piece of 3 x 12 Douglas fir to span the crater caused by the sinking trailer, I jacked the trailer up using the Douglas fir as a support for the jack pad. I then then backed my truck under the trailer and moved to a better location. l believe if you block the tires, release the ball in your hitch, then use a floor jack you can move your truck out from under the trailer. You also should consider using jack stands while your jack is being repaired.
Edited by Bhill 2013-08-14 7:20 AM
Posted 2013-08-14 5:55 PM (#154008 - in reply to #153984)
I just reread this post...you first need to unbolt the tube on the gooseneck to take the weight of the truck off the jack...then uncouple the hitch from the truck...then shove the tube up to get the truck out of the way then lift the front of trailer to get the weight off the jack...
china doll
Reg. Jul 2012
Posted 2013-08-17 12:23 PM (#154072 - in reply to #153984)
Take the cover off the jack and check the grease and look at the cogs. You may be able to unstick it with a large screwdriver or something.. This happened to me one time and I went back for repair and it just started working.
Posted 2013-08-18 8:44 PM (#154099 - in reply to #154072)
Originally written by china doll on 2013-08-17 12:23 PM
Take the cover off the jack and check the grease and look at the cogs. You may be able to unstick it with a large screwdriver or something.. This happened to me one time and I went back forĀ repairĀ and it just started working.
Don't forget his jack has lots of potential energy locked in those cogs...sticking a screw driver in there could be interesting...
Posted 2013-08-18 8:45 PM (#154100 - in reply to #153984)
So did you get it resolved yet?
