exhaust brake Powerstroke manual trans
trot-on
Reg. Dec 2009
Posted 2013-08-02 4:59 PM (#153764)
Subject: exhaust brake Powerstroke manual trans
2001 F350, manual transmission. Thinking about a exhaust brake. A friend suggested the PacBrake. any thoughts on the subject? I know little about them, but understand it would be a good addition for slowing things down, especially in the mountains. How does this work different than just down shifting?
Saddleup
Reg. Apr 2012
Posted 2013-08-02 7:04 PM (#153767 - in reply to #153764)
Subject: RE: exhaust brake Powerstroke manual trans
With a manual trans you already have a second brake, just down shift watching your tach so you don't over rev your engine. Assuming your trailer brakes work good, your manual trans is back up or often in addition to on long downhill stretches  A jake or exhaust brake really is not needed with manual trans, usually used with auto trans as auto trans has no holdback on down hill other than holding unit in a lower gear, which can be damaging to a trans if not careful.
Posted 2013-08-02 7:47 PM (#153768 - in reply to #153767)
Originally written by Saddleup on 2013-08-02 7:04 PM
  Say What !!?
Saddleup
Reg. Apr 2012
Posted 2013-08-02 8:19 PM (#153771 - in reply to #153764)
You read it right...  not really needed with a manual trans....  and you guys don't even have the Rocky Mountains to contend with... lol
trot-on
Reg. Dec 2009
Posted 2013-08-02 8:53 PM (#153775 - in reply to #153767)
So what do 18 wheelers have on them? Isn't a jake brake a type of exhaust brake? And we do have the Rocky mountains.... ;-) Even had a song written about them.
Saddleup
Reg. Apr 2012
Posted 2013-08-02 9:07 PM (#153779 - in reply to #153764)
The majority of todays 18 wheelers have auto trans, and was referring to our friends in NC. not having the Rock Mountains, been to Texas and Eastern seaboard... lol
siseley
Reg. Jul 2006
Posted 2013-08-02 10:21 PM (#153782 - in reply to #153764)
Saddleup;You may be mistaken. A diesel will not slow down when you take your foot off the fuel like a gas engine. It tends to kind of go into wheezy land. True, you get SOME slowing from a manual gear change, but an exhaust brake is probably one of the BEST things you can have for mountain driving. YES, I DO drive in the Sierras, which are even higher than the Rocky's in places. And just returned last week from the Southern Sierras in fact. Wonderful rides up there, and out of the normal 110 degree temps of home here.
Saddleup
Reg. Apr 2012
Posted 2013-08-02 10:40 PM (#153783 - in reply to #153764)
Sorry I respectfully disagree,  diesels will slow you down if you gear down according to your tach. I have owned and drivel diesels since 1990 and always towing a trailer with either horses or cattle on board. However I am glad everyone has their own opinion and respects the other. happy motoring.......
Posted 2013-08-03 1:32 AM (#153786 - in reply to #153764)
Edited by PaulChristenson 2013-08-03 1:34 AM
hornet
Posted 2013-08-03 1:45 PM (#153794 - in reply to #153786)
I have an exhaust brake on my C4500 that I can turn on and off. It considerable slows down the truck more when turned on. The whole point of a jake brake or exhaust brake is to restrict air flow. All engines are fancy air compressors, when you're not giving it fuel it is still pumping air. To increase engine braking, you restrict air flow, hence the exhaust brake.
As to the original question, if I were you I'd read over the forums on http://www.thedieselstop.com/ and see which after market exhaust brake those folks like.
trot-on
Reg. Dec 2009
Posted 2013-08-03 1:55 PM (#153795 - in reply to #153794)
Originally written by hornet on 2013-08-03 1:45 PM
I have an exhaust brake on my C4500 that I can turn on and off. It considerable slows down the truck more when turned on. The whole point of a jake brake or exhaust brake is to restrict air flow. All engines are fancy air compressors, when you're not giving it fuel it is still pumping air. To increase engine braking, you restrict air flow, hence the exhaust brake.As to the original question, if I were you I'd read over the forums on http://www.thedieselstop.com/ and see which after market exhaust brake those folks like.
Thanks. I had been reading those, and a couple other truck forums. Some have just done a modification to the EBPV, others install a system. I'm still reading, and trying to grasp and understand everything.
Posted 2013-08-03 8:45 PM (#153798 - in reply to #153764)
Saddleup ... In a comparison between a gasoline engine and a diesel ... The diesel has little engine braking with out some sort of restrictor.  Here's an explanation copied from the net.
A gas engine has more engine braking than a comparable displacement diesel because at low throttle levels a gas engine is working against a closed throttle plate. A diesel has a wide open intake manifold without a throttle plate.
Think of a diesel piston and cylinder like an air cylinder. If you press the piston up to near TDC with the valves closed, it takes a lot of pressure, right? But guess what, after rotating beyond TDC all that compressed air now pushes down on the piston to accelerate it to BDC.
A gas engine will generate about 25" of vacuum with the throttle closed, so when the piston comes up to TDC, very little pressure is there to push the piston on the down stroke. Then, when it wants to pull in a fresh charge, the engine has to pull against the vacuum. All this consumes energy and creates what is termed "compression braking".
Of course, a diesel does produce some compression braking due to mechanical losses and heat generation, but a similar displacement gas engine will always generate more "compression" braking.
Posted 2013-08-03 8:46 PM (#153799 - in reply to #153795)
Originally written by trot-on on 2013-08-03 1:55 PM
http://www.bankspower.com/techarticles/show/38-Why-Add-An-Exhaust-B...
Saddleup
Reg. Apr 2012
Posted 2013-08-03 9:11 PM (#153800 - in reply to #153764)
As I said a diesel will provide some braking using a manual trans, down shifting using your tach....... I still stand by it from 40 years of towing, I do appreciate your quotes from the net, however remember boys..........  they are selling jake and compression brakes, its the net they will tell you what they want you to hear...
However, I respect your take on it... please respect mine..
tks
Posted 2013-08-03 9:51 PM (#153802 - in reply to #153764)
It is not a matter of respecting opinion or "take"
Logical explanations stand on their own.  Trot-on can downshift a gasoline engine car and his diesel engine truck to experience inherent engine braking between the two.
hornet
Posted 2013-08-04 12:19 PM (#153807 - in reply to #153800)
Originally written by Saddleup on 2013-08-03 9:11 PM
tks
I don't think any one has called you names to disrespect you. You've stated your opinion no need to keep implying your right and everyone else is wrong. If anything that's disrespecting us. I'm not a boy.
Bhill
Reg. May 2013
Posted 2013-08-04 1:25 PM (#153809 - in reply to #153764)
I have a 2011 Ford with an integrated exhaust brake-- I have pulled a 39ft fifth wheel and our 34 ft Bloomer down some fairly steep grades-- I would never own another truck without this option.
gonzo1066
Reg. Oct 2010
Posted 2013-08-04 5:40 PM (#153812 - in reply to #153764)
Exhaust brake not needed with a manual trans????     Sorry but where I tow I use the exhaust brake every time I slow down or stop.  Apparently you have never decended a 6-7 or 8% grade with 17.000# of trailer behind you.    I am on my 5th diesel manual pickup for towing and every one of them has had a exhaust brake, my service brakes last well over 100,000 miles and the trailer brakes at least that long.
trot-on
Reg. Dec 2009
Posted 2013-08-04 7:44 PM (#153815 - in reply to #153812)
Originally written by gonzo1066 on 2013-08-04 5:40 PM
So which one(s) do you like? Commercial install, or a DIY? And while I do down-shift my man.transmission on steep grades, because of my trucks gear ratio, I really feel I need to slow way down with brakes first before I down-shift. Assuming that is where the exhaust brake would really come in???
slowrider
Reg. Apr 2010
Posted 2013-08-04 8:51 PM (#153821 - in reply to #153764)
Here in PA, we don't have the Rockies, but we do have steep climbs and descents. 2 years ago, my husband added a Pac-brake brand exhaust brake to his 2001 Dodge with a manual transmission. He thinks it's great, one of the best things he's done to his truck. He put it on himself, and it cost about $1300.
gonzo1066
Reg. Oct 2010
Posted 2013-08-04 10:40 PM (#153823 - in reply to #153815)
Originally written by trot-on on 2013-08-04 5:44 PM
I have used the PacBrake on all of the trucks.  The current PRXB is considered a "State of the art" with its exhaust bypass valve.   The fact that  PacBrake stands behind the product is the biggest thing for me as a mechanic.   The brake will help your truck to slow the load so you can downshift easier without overreving the engine.  It usually takes a bit of towing to get familiar with using the brake in the most effective way.  After you have a ex brake you will wonder how you ever got along without one.
Posted 2013-08-05 1:27 AM (#153827 - in reply to #153800)
tks
Hmmm...respect is earned...:rolleyes: http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=179...
Edited by PaulChristenson 2013-08-05 1:27 AM
cajunmuleman
Reg. Oct 2011
Posted 2013-08-05 6:35 AM (#153829 - in reply to #153764)
Thank You Paul
hogtownboss
Posted 2013-08-05 10:44 AM (#153833 - in reply to #153764)
10001001001002525
Originally written by trot-on on 2013-08-02 4:59 PM
Since your question was turned into a piss match, I will give you my opinion. YES, the PacBrake is one of the best aftermarket EB you can buy for this type of truck. And YES, I would rather use the PacBrake or any other type of EB long before I would use the tranny to slow me down!
trot-on
Reg. Dec 2009
Posted 2013-08-05 1:49 PM (#153839 - in reply to #153764)
Thanks y'all !! (and I can read thru the pissing matches and get the info I need.) I think I have a better understanding of them, and will look into it further
windy
Reg. Oct 2004
Posted 2013-08-05 5:22 PM (#153841 - in reply to #153764)
The PAC-Brake is an excellent exhaust brake. And yes, it makes a big difference in what you can descend a steep hill with. It allows you to be safer, and to reduce wear and tear on your rig. And on yours specifically, it will probably make your rotors last longer, and warp and crack less! I'm in the Rocky Mtns, and haul and have hauled through the mountains all my life, both with pick-ups and trailers of all sizes, and tractor trailers.
The difference between an exhaust brake and a jake brake(Jacobs engine brake) is basically an exhaust brake restricts the air flowing out of the engineby plugging(mostly) the exhaust pipe. The jake brake actually opens the exhaust valve(s) at the top of the compression stroke, releasing the compressed air  and absorbing the energy instead of allowing the compressed air to expand again and push the piston down. It basically turns your engine into an air compressor, the wheels are what drive it. Clear as mud? Hope this helps a little!
Bill
Posted 2013-08-05 11:01 PM (#153852 - in reply to #153764)
These after market products only work on the older Ford Powerstrokes. 6.0L or 7.3L
B&D did have an exhaust brake for the 6.0L with automatic tranny.  The one I have on my 2006 truck worked very well.
The new Ford 6.7L using the turbo to restrict exhaust flow and I find it works very well if I use it properly.  It don't stop the truck, But it will hold speed on steep grades.  1st gear is 25mph, 2nd gear is 40 mph and 3rd gear is 60 mph.  These speeds are all around 3000+ rpms.  Which is where you get enough back pressure to produce some braking.  At least with my 13,000 lbs trailer.
Terrye
Reg. Nov 2010
Posted 2013-08-06 12:42 PM (#153868 - in reply to #153764)
with a decent size trailer your 7.3 diesel will not slow you down on big hills.
I added an electronic SP Diesel module that turns your valve in your turbo into an exaust brake.
when i went from by three horse tag along trailer to my 4 horse gooseneck the gooseneck pushed me down the grapevine in california I5.
The SP diesel "brake" saved my brakes and really works.
http://www.spdiesel.com/exhaust_brake.htm
It is common knowledge that a diesel does not have the backpressure to slow you down like a gas engine.
Good luck with your truck.
Terry
horsey1
Reg. Dec 2004
Posted 2013-08-06 1:54 PM (#153869 - in reply to #153868)
Originally written by Terrye on 2013-08-06 12:42 PM
Terry
Hmm. I thought it was related to compression ratio in the engine, of which a diesel is much, much higher.
Posted 2013-08-06 10:59 PM (#153881 - in reply to #153869)
Originally written by horsey1 on 2013-08-06 10:54 AM
Originally written by Terrye on 2013-08-06 12:42 PMIt is common knowledge that a diesel does not have the backpressure to slow you down like a gas engine. Good luck with your truck.Terry
While the diesel engine has much higher compression ratio, it is not working against any restriction... therefore a jake brake, inlet, or exhaust restrictor is needed.  See my post on page one of this thread for an logical explanation.
windy
Reg. Oct 2004
Posted 2013-08-07 2:23 PM (#153886 - in reply to #153881)
Originally written by hosspuller on 2013-08-06 10:59 PM
Exactly. And that is also why a jake works so well- you compress the air on the compression stroke- then at the top of the stroke, you release all that compressed air so it doesn't push the piston back down.
Posted 2013-08-07 10:33 PM (#153893 - in reply to #153764)
All the years I've been driving, manual transmissions and automatics, gas and diesel, with or without trailers, I've always used lower gears to retard my passage down hills. Now I read where it didn't do any good and my efforts were for nought. Bugger
windy
Reg. Oct 2004
Posted 2013-08-09 11:19 AM (#153914 - in reply to #153893)
Originally written by gard on 2013-08-07 10:33 PM
Your efforts weren't for naught- probably saved you more than a few bucks over the years as far as replacing brakes! To say nothing of the gray hairs you didn't get cause you didn't scare yourself!
Posted 2013-08-11 9:28 AM (#153936 - in reply to #153914)
My comment was one of facetiousness. When I raced sports cars, I had to learn how to heel and toe downshift with rev matching. I've down shifted now for several decades, and saved myself many brake pads over that time as a result.
