Opinions on generator and where to put it
BettyBarrelRacer
Reg. Dec 2003
Posted 2013-07-23 3:32 PM (#153501)
Subject: Opinions on generator and where to put it
Just bought a new LQ. It is prewired for generator, but does not have one. My husband wants to put on a propane generator. Not sure what I want. Other question, where does it need to go? Tack compartment or on the hay rack. Mine is not a pod. If you do gas, where is your storage tank? Thanks
Posted 2013-07-23 4:30 PM (#153504 - in reply to #153501)
Subject: RE: Opinions on generator and where to put it
Just an opinion on fuel ... Propane is nice, no hassle but if you run out, one has to take the trailer to refuel.  With gasoline, a spare jug can refuel.
adeberti
Reg. May 2007
Posted 2013-07-23 5:05 PM (#153505 - in reply to #153501)
i would not got with the tack comportment (or other internal parts of the trailer) as proper ventilation might be an issue.
Posted 2013-07-23 6:28 PM (#153507 - in reply to #153501)
Originally written by BettyBarrelRacer on 2013-07-23 3:32 PM
  If it's prewired for a generator, then where does the prewire run to? Roof rack? Ventilated side compartment? Ventilated rear tack compartment? Under gooseneck? etc.. Go with the gasoline unless you plan to carry alot of LP or don't plan on running it for any length of time.
longearsruletwo
Reg. Feb 2011
Posted 2013-07-23 6:30 PM (#153508 - in reply to #153501)
I have an Onan 5500 propane generator.  I had it mounted in the back of my truck and used bottles, which worked good if you ran out.  Easier to take bottles.  They put a receptacle on the side of the bed to hook the trailer into and ran a cord to the generator so I could start it from inside.  Got a new truck and didn't put it back in.  Haven't used it that much in the past few years.  Most every where we go has hookups now.  I have it for sale if anyone is interested.  Low hours.
china doll
Reg. Jul 2012
Posted 2013-07-23 7:07 PM (#153509 - in reply to #153501)
I have a factory Onan 2400 that is mounted under the gooseneck and the exhaust comes out below at the running board. I have a built in tank and I can run the generator for DAYS and hardly use any gas. I love my built in generator with a built in tank.
BettyBarrelRacer
Reg. Dec 2003
Posted 2013-07-24 12:11 AM (#153515 - in reply to #153507)
Originally written by retento on 2013-07-23 6:28 PM
It runs to the tack compartment. But there is no vent there as of now. I had heard that propane will not run very long. Still taking all suggestions and advice. Thanks
tom-tom
Reg. Feb 2008
Posted 2013-07-24 8:13 AM (#153517 - in reply to #153501)
100100100
Mine is on the hayrack. Keeps the noise and heat away. Fuel tank is mounted under floor of trailer. I had to install an extra fuel pump to push the fuel to the roof as the factory Onan pump had some issues sucking fuel that far after it got some age on it. Now I have no problems. Biggest disadvantage to having a roof mounted genset is servicing it can be a pain in the butt; however I imagine that would be the case regardless of where it is mounted.
siseley
Reg. Jul 2006
Posted 2013-07-24 9:24 AM (#153518 - in reply to #153501)
Ours is a propane in a vented compartment. I LOVE the propane one, as it does not smell so bad, and handling a couple of bottles is easier, and a whole lot less messy than carrying and pouring gas. Yes, I think it uses a lot of propane next to the small one I have for camping. But that one won't run the microwave, and A/C either. Our propane is mounted under the gooseneck on a rack, and has two 20lb bottles, which can be changed out in 5 minutes.
hogtownboss
Posted 2013-07-24 11:42 AM (#153525 - in reply to #153508)
10001001001002525
Originally written by longearsruletwo on 2013-07-23 6:30 PM
I tried to send you a pm about your generator and it will not go through.  Send me the measurements and a price if you do not mind.
Bhill
Reg. May 2013
Posted 2013-07-24 12:54 PM (#153526 - in reply to #153525)
Originally written by hogtownboss on 2013-07-24 11:42 AM
I was just on the Onan website looking around- Perhaps this link will help with the measurements?>>>>http://www.cumminsonan.com/www/html/Common/pdf/specsheets/a-1425.pdf
longearsruletwo
Reg. Feb 2011
Posted 2013-07-24 6:15 PM (#153535 - in reply to #153501)
Your PM's came thru but I can't reply to them.  Those specs are the same as mine.  Only mine has a black case.  It is a Marquis Gold.  We have all the wiring from when it was in the truck and the receptacle box.  We are asking $3,000 but will negotiate.  We got that price from an Onan dealer.  Even have the exhaust pipe for it.
Spin Doctor
Reg. Nov 2008
Posted 2013-07-26 11:38 AM (#153567 - in reply to #153501)
I've had pickup box ones, rear tack ones, hay rack ones and a manger mounted one. I like the manger mounted one. BUT next time, I am going to run the exhaust thru to the roof. As now, you can't tie horses on the side of the floor exited exhaust on the manager mounted one. I have never seen this, but should be easy to do...
Pickup box is easy to get stolen, and just a pain to be out in the weather and to close to the sleeping quarters as is the under the noise mounted ones.
The rear tack took up to much valuable tack space. Had issues with stuff falling on generator and tack always smelled like exhaust.
The hay rack mounted one was never serviced/checked as often as needed as to much a pain to crawl up and down. Also was out in the weather more, added more weight, wind issues to roof, and just a pain to take down if ever needed. Yes, it was easy to service if you remembered the right tools to take up the ladder.
The next trailer I get, it will go in the manager with a slide underneath and top exited exhaust.
Fuel tank is in bottom of managers.
As far as propane, ours have always been gas. Lots easier to fill gas tank than mess with bottles IMO.
Good luck!
Edited by Spin Doctor 2013-07-26 11:40 AM
flyinghfarm
Posted 2013-07-26 9:54 PM (#153581 - in reply to #153501)
1000100100
We have an Onan, mounted on the floor in the rear tack.  There is a screened louvered air intake vent on the door, and an air exit out the bottom of the trailer, in addition the exhaust is routed down and then across the rear to the off side back corner.  The unit is enclosed in an Onan spec aluminum insulated housing, very very quiet.  The 20 fuel tank is gasoline, and mounted in the storage compartment under the manger. You can fill at the gas pump when you fuel up your truck, or add fuel via a gas can if need be.  The remote switch is in the LQ.  We also carry an air compressor under the bottom saddle rack sitting on top of the generator case.  I still carry three saddles on racks, have 2 bridle racks, rake and etc racks, and a brush box in the tack room. I also keep polo wraps, horse hoses and a long multipocket organizer in there. Everything else 9tables, chairs, rugs, BBQ grill, panniers etc is in the 2 storage compartments under the mangers, and the hay rack.  If I ran out of room, I most likely didn't have to have it!  We love this arrangement, have had it for 7 years and still love it.
Posted 2013-07-26 10:08 PM (#153584 - in reply to #153501)
If you go with a propane powered generator...make sure you get the cold weather kit for your unit if you plan to use it when temps get down below 32 degrees F
