Poll Sway bars and backing
whoaboy
Posted 2013-07-12 11:51 AM (#153309)
Subject: Sway bars and backing
I have a bumper pull trailer that has a load distribution hitch with sway bars. My question is in regards to backing up. Does one have to take off the sway bars in order to back into things such as a camping spot, driveway, etc.?
cutter99
Reg. Sep 2007
Posted 2013-07-12 4:34 PM (#153311 - in reply to #153309)
Subject: RE: Sway bars and backing
10010010010025
I had one trailer with sway bars years ago and never took the sway bars off while towing- either forwards or backwards. You should be able to back just fine with them on!
trot-on
Reg. Dec 2009
Posted 2013-07-12 9:52 PM (#153317 - in reply to #153309)
No issues. Tower thousands of miles with them on my old set up
RTSmith
Posted 2013-07-13 9:09 AM (#153323 - in reply to #153309)
If you are speaking of the weight distribution hitch bars, yes you can drive anywhere and anyhow with them. If you have a true anti-sway device that you use, they typically clearly state to release tension on them before extreme turning or backing. If doing a lot of twisting around, I'd remove it rather than just loosen it.
