Bad connection?
ClaudiaIN
Reg. Feb 2009
Posted 2013-07-03 3:45 PM (#153120)
Subject: Bad connection?
Our fridge is not working on LP unless it also have electric plugged in- batteries are fully charged
Could it be a bad connection somewhere?  It doesn't make sense --
Bhill
Reg. May 2013
Posted 2013-07-03 5:47 PM (#153124 - in reply to #153120)
Subject: RE: Bad connection?
Does your other gas appliance(s) work? Assuming you may have a gas stove,water heater etc.
ClaudiaIN
Reg. Feb 2009
Posted 2013-07-04 8:33 AM (#153135 - in reply to #153124)
yes- the stove and hot water heater work
Bhill
Reg. May 2013
Posted 2013-07-04 5:04 PM (#153143 - in reply to #153135)
Maybe this will help see link...http://www.rvrefrig.com/gas-refrigerators-troubleshooting.htm
walkin
Posted 2013-07-05 5:50 PM (#153169 - in reply to #153120)
500100
Thermocouple.  My frige has not worked on gas for 5 years.
ClaudiaIN
Reg. Feb 2009
Posted 2013-07-06 11:23 AM (#153179 - in reply to #153169)
But that's the WEIRD part-- It DOES work- as long as the trailer is hooked up to electricity--   I'm going to go out today or tomorrow and try again-- maybe it was just a fluke a couple of weeks ago.
cajunmuleman
Reg. Oct 2011
Posted 2013-07-06 2:10 PM (#153180 - in reply to #153120)
With outside access door removed do you see a small flame? Try blowing out burner area and exhaust area with air. Also see if the switch is calling for propane
cajunmuleman
Reg. Oct 2011
Posted 2013-07-06 2:11 PM (#153181 - in reply to #153120)
Is it a standing pilot or spark ignition model?
RTSmith
Posted 2013-07-06 7:16 PM (#153184 - in reply to #153179)
Originally written by ClaudiaIN on 2013-07-06 11:23 AM
This tells me you are having a 12V issue with the trailer. The fridge isn't getting 12V when it isn't plugged in. You need to do some investigating on your battery/12V system. Is there a disconnect switch turned off? Is there a circuit breaker tripped (a lot of older trailers have these)?
ClaudiaIN
Reg. Feb 2009
Posted 2013-07-08 6:48 PM (#153231 - in reply to #153120)
That makes sense RT Smith-- thanks --- I'll try that--
