Trails West (Adventure) rubber wall ridge??
skassi
Reg. Jun 2013
Posted 2013-06-30 1:12 AM (#153022)
Subject: Trails West (Adventure) rubber wall ridge??
Good day all! Hope you are well!
A couple of months ago I purchased a Trails West Adventure MX (2h). I love the trailer but have been noticing a bit of an issue with the ridge that is formed where the rubber lining meets the body of the trailer on the most forward wall of the horse compartment. My mare is 15.1 and makes enough contact with the wall during travel that it is leaving a horizontal line the length of her body mostly on the hind quarter.
I hadn't been too concerned about it until today when some comments on a scorecard for my horse noted "whip mark". Oy! I do not whip my horse and so obviously this is a concern for me.
Does anyone know what I'm talking about? Does anyone have some ideas re: what I could do about the ridge? Any ideas?
Thanks so much!
trot-on
Reg. Dec 2009
Posted 2013-06-30 2:11 PM (#153034 - in reply to #153022)
Subject: RE: Trails West (Adventure) rubber wall ridge??
can you take a picture of it?
skassi
Reg. Jun 2013
Posted 2013-06-30 2:39 PM (#153036 - in reply to #153022)
Thank you for the reply!
I will grab a pic this evening or tomorrow. Will post ASAP
skassi
Reg. Jun 2013
Posted 2013-07-04 2:20 AM (#153129 - in reply to #153022)
Hey there,
Sorry for the delay.
Here are a few pics!
Posted 2013-07-04 8:53 AM (#153137 - in reply to #153022)
1000500100100100252525
Hello I have seen this before with other trailer what I have see others do it cut a piece of rubber in the shape of a triangle and glue it on like trim is works for them on my trailer I had the rubber put on all the way up to the horses shoulder
Posted 2013-07-04 11:09 AM (#153140 - in reply to #153022)
That looks like Rumber Sheeting.  You could glue some additional Rumber sheets up higher,
Set it so it is right where the existing sheet stops and continue it high enough that she can't lean against an edge of it.
Then when the mare leans against it, She won't have a line because the edge will be higher than her body.
skassi
Reg. Jun 2013
Posted 2013-07-06 11:55 PM (#153189 - in reply to #153022)
Hey there!
Thanks so much for the suggestions! :)
I went hunting for some rubber sheeting this afternoon and ended up brainstorming with a fellow at our local Rona Revy (hardware store). I settled on a makeshift trim option using 1/2" thick (foam) pipe insulation (cut approx. 1" wide with a notch on the underside to overlap the rubber) and covered the rubber edge and foam with the fuzzy side of 2" wide industrial strength Velcro.
It feels good and I'll find out if my mare manages to whip herself on Wednesday!
Thanks again!
Here are some new pics:
AZgrulla
Reg. Jan 2009
Posted 2013-07-08 6:15 AM (#153209 - in reply to #153022)
Nice.
chicory
Reg. Sep 2013
Posted 2013-10-21 7:01 PM (#155462 - in reply to #153022)
Looks great! Did it last? Did your horse's whipmarks end?
skassi
Reg. Jun 2013
Posted 2013-10-22 9:33 AM (#155467 - in reply to #153022)
Thank you Chicory!Yes it has and yes it did! :)
skassi
Reg. Jun 2013
Posted 2013-10-22 9:40 PM (#155480 - in reply to #153022)
Posted 2013-10-22 9:46 PM (#155481 - in reply to #153022)
That is a great idea nice job
skassi
Reg. Jun 2013
Posted 2013-10-22 10:06 PM (#155482 - in reply to #153022)
Sorry for the repeat. I also should have mentioned it did resolve the problem.Thank you loveduffy
