Hooking up 12v battery and breakaway to horse trailer
Sunnyfield
Reg. Jun 2013
Posted 2013-06-23 12:54 AM (#152893)
Subject: Hooking up 12v battery and breakaway to horse trailer
I have been looking for a diagram of the wiring to install my 12v battery and breakaway switch to my horse trailer. My battery has a red side and a blk side. I understand so far that I should take one wire fr the breakaway and splice it into the blue wire on my junction box fr the brakes. The other wire on the breakaway being wired onto a wire that will be the hot wire (red side of battery?). I also want it to be able to get a charge fr my 7 pole connector fr the vehicle, so I am not sure how to test which slot is the one that will be giving the charge from the vehicle side to the trailer connector. I would assume that my blk side of the battery will have a wire going to ground on the trailer and then the hot wire (red side of battery) will have a spliced connection that goes to the brakes and also another wire that is receiving the charge from the vehicle. Is this correct?
cajunmuleman
Reg. Oct 2011
Posted 2013-06-23 7:49 AM (#152894 - in reply to #152893)
Subject: RE: Hooking up 12v battery and breakaway to horse trailer
This may help. When looking at the truck receptacle the bar in the one o'clock position is 12 v positive (red) from the battery, hope this helps
cajunmuleman
Reg. Oct 2011
Posted 2013-06-23 8:13 AM (#152895 - in reply to #152893)
This should help. You can verify the terminals with a DC volt meter or DC test light.
Posted 2013-06-25 12:57 AM (#152931 - in reply to #152893)
Originally written by Sunnyfield on 2013-06-23 12:54 AM
halfway down the page http://www.etrailer.com/faq-trailer-breakaway-kit-installation.aspx
Edited by PaulChristenson 2013-06-25 12:59 AM
