no power at + pin of trailer receptacle
Show-Dad
Reg. Feb 2012
Posted 2013-06-09 6:17 PM (#152572)
Subject: no power at + pin of trailer receptacle
I have no power at the + pin of the trailer receptacle on my 06 Ram. So the interior lights on my trailer do not work. The trailer plug is fine,as everything works when I plug the trailer into itself ( I mounted a battery box & receptacle to be able to use the lights when the truck is not hooked up) I think this happened a couple years ago & it was a fuse, this time all the fuses appear to be good.
yeehaw
Posted 2013-06-09 6:54 PM (#152574 - in reply to #152572)
Subject: RE: no power at + pin of trailer receptacle
you really need an ohm-meter to correctly check fuses, they really need to be removed from the circuit to be checked. If you don't have a ohm-meter a visual inspection might work, but sometimes you could miss a blown fuse.
good luck
MrSteve
Reg. Jul 2012
Posted 2013-06-09 6:57 PM (#152575 - in reply to #152572)
Did you have the truck key to "run" when trying the inside trailer lights? My Chevy doesn't need the key on but my Ford dose, not sure how dodge is setup.
Show-Dad
Reg. Feb 2012
Posted 2013-06-09 7:25 PM (#152576 - in reply to #152572)
visual inspection of the fuse looked ok, swapped it out with a new one & same results. Did not check either fuse with an ohm meter. Does not make a difference if the ignition is on or off.
MrSteve
Reg. Jul 2012
Posted 2013-06-09 7:37 PM (#152577 - in reply to #152572)
Bad relay? Give a check in the owners manual for its location.
yeehaw
Posted 2013-06-10 7:08 AM (#152585 - in reply to #152577)
Originally written by MrSteve on 2013-06-09 8:37 PM
ditto that!!!
