Location: Rochester, NY | The trailer: 1998 Featherlite 2-horse BP, weighing 2350lbs. Pulling one 1100lb horse plus hay and grain... though option to pull 2 would be nice
The truck (ad I found):
1999 Ford F150
NYS INSPECTED
MINT CONDITION
NEW PARTS
READY TO DRIVE
***ONLY 57,000 MILES***
Engine Specifications
Type: Gas V8
Horsepower: 360 @ 4750 RPM
Torque: 440 @ 3000 RPM
Max Payload: 800
Drivetrain
Drivetrain: Rear Wheel Drive
Transmission: 4 speed Automatic w/OD, Electronic
Safety
Air Bag-Frontal-Driver
Air Bag-Frontal-Passenger
Air Bag-Passenger Switch (On/Off)
Brakes-ABS
Brakes-Type-4 Wheel DISC
Engine Immobilizer
Headlights-Automatic
Comfort & Convenience
Air Conditioning-Front
Cruise Control
Keyless Entry
Max Seating Capacity: 3
Mirror(s)-Power
Power Locks
Reading Lamps-Front
Seat Trim-Cloth
Seat-Power Driver
Seats-Front Bench-Split
Steering Wheel-Adjustable
Steering-Power
Windows-Power |
| I pull the same trailer with a chevy 1500, 2 horses all the time, so Yes! |
    Location: Indiana | I would add "trailer brake" controller. We did this for several years, but not in the mountains and give yourself PLENTY of time to STOP-especially if you are hauling 2 |
      Location: Rocky Mount N.C. | Don't know where you got those engine HP and TQ numbers but they are way off base... That's the numbers for a 2001 Lightning SVT. Should read... 2-valve SOHC, 5.4 liter, 260 hp and 350 lb·ft ratings for 1999 and later model years
Edited by retento 2013-06-03 1:06 PM
Location: Rochester, NY | Retento - This is just the info the dealer had put in the ad...nothing else
Edited by mayelix 2013-06-03 1:57 PM
        Location: Vermont | Originally written by mayelix on 2013-06-03 1:55 PM
Retento - This is just the info the dealer had put in the ad...nothing else If he inflated the horsepower that much...one wonders if he deflated the mileage the same percentage... |
Location: Rochester, NY | Actually kelley blue book says the same as the ad:
http://www.kbb.com/ford/f150-regular-cab/1999-ford-f150-regular-cab... |
     Location: Texas | http://www.fordf150.net/specs/99tow.php .......When it comes to the phrase "safely tow" and half tons, you will find many have different definition of that phrase....Link to 99 tow specs above
Edited by trot-on 2013-06-04 9:40 PM
   Location: Arkansas | Did I miss on the specs a "trailer towing package" with transmission cooler etc? What gear ratio is the rear end? |
