Tight Turns
blackcows
Posted 2013-06-02 5:55 PM (#152408)
Subject: Tight Turns
100100100100252525
Is it hard on axles, tires, etc to make tight turns and backs? It's not as if I do it every day but with a long flatbed pickup it's possible to basically spin the trailer in a circle and the tires start to do funny things like toe out and toe in...this is what they are supposed to do correct?
Posted 2013-06-02 6:40 PM (#152410 - in reply to #152408)
Subject: RE: Tight Turns
Soak the pavement where the tires are going to scuff, and the water will lessen the effects...:)
hornet
Posted 2013-06-02 8:17 PM (#152411 - in reply to #152408)
It's not good on hub and bearings, but sometimes is unavoidable. I try not to get into this condition if possible, especially on hard surfaces.
Posted 2013-06-02 10:07 PM (#152414 - in reply to #152408)
Ditto
I once saw a heavy LQ trailer peel a tire off a rim. It really puts a lot of stress on the running gear.
RTSmith
Posted 2013-06-03 8:17 AM (#152419 - in reply to #152408)
And if it is hard enough to peel a tire off of the wheel- fair chance of bending the torsion swing arm also. Have seen it done on large LGs that were loaded and on solid surfaces.
