Poll Weekender LQ Question
TXfoxtrot
Reg. May 2013
Posted 2013-05-30 4:20 PM (#152348)
Subject: Weekender LQ Question
I have just had a water tank, 12 v water pump, 6 gal. electric water heater and sink installed in my small LQ.  Can anyone tell me why there is a horrid sulfur smell and taste to the water.  I haven't turned on the water heater.  There is also an outside spigot which comes off the water line before the water heater.  The horses won't drink the water.
I had all of this installed by a "professional" RV shop, but they have been difficult with my questions.  I guess after the thousands of $$ I've spent with them, they can't follow through with the customer service.  So I'm turning to my friends at HTW!
I would like to install an under cabinet water filter, but am not certain it will correct the problem.  Have any of you experienced this?
pchoofinit
Reg. May 2013
Posted 2013-05-30 5:25 PM (#152350 - in reply to #152348)
Subject: RE: Weekender LQ Question
you can go to Walmart, to the RV section and purchase for around $20 a water filter that connects to your hose before the water goes into your trailer. Perhaps that may help. Also adding vinegar to their water at home, they can get used to it, and you can add it on the road too. Good luck
Wray
Reg. Jul 2012
Posted 2013-05-30 10:07 PM (#152361 - in reply to #152350)
You didn't mention the source of your water but our well in Gonzales has a fair amount of sulfur smell, when we fill the tank which has a small vent, the sulfur smell/taste diminishes quite a bit overnight. When we hook up to the well we just deal with it. For taste you would be looking for a carbon filter.
CYA Ranch
Reg. Feb 2009
Posted 2013-05-31 2:36 PM (#152371 - in reply to #152348)
Run a bunch of water through the system to flush it out. First time I use my trailer each spring it has a funky odor.
luckygirl03
Reg. Jun 2013
Posted 2013-06-01 12:49 AM (#152377 - in reply to #152348)
I just had this problem. It's whatever water you have used to fill the tank with. You have to drain it. Even if you haven't used the water heater some water maybe trapped in there. Drain the water heater. You can put a small amount of bleach in your main tank, don't overdo it, it can corrode the pipes, run fresh water through.
Originally written by TXfoxtrot on 2013-05-30 4:20 PM
Posted 2013-06-01 10:38 AM (#152382 - in reply to #152371)
Originally written by CYA Ranch on 2013-05-31 11:36 AM
This ... You're used to the house water taste.  So use your house water to flush the system.  Remember to open all the taps to flush the system completely.   There may be some plastic taste at first, but that will fade.
SuzieQ
Reg. Aug 2009
Posted 2013-06-02 8:14 AM (#152394 - in reply to #152348)
Thank you all.  I am using household water, which has gone thru a softner and iron filter but I will try flush it and see if that helps.
Posted 2013-06-02 8:49 AM (#152395 - in reply to #152348)
http://rvbasics.com/techtips/sanitizing-your-rv-fresh-water-system.html
TXfoxtrot
Reg. May 2013
Posted 2013-06-03 9:01 AM (#152420 - in reply to #152348)
Thanks!
