Installing corner water tank, pump, 12v/deep cycle marine battery - how hard is it?
Fancy That
Reg. Jan 2012
Posted 2013-05-17 3:24 PM (#152096)
Subject: Installing corner water tank, pump, 12v/deep cycle marine battery - how hard is it?
I swear I tried to use "search" here, but couldn't find anything that talked about the project that I THINK my husband can do.
My local trailer place quoted me $450 in LABOR ALONE, to do the following:
- Install corner upright water tank
- Install marine grade/deep cycle/12v battery
- Run spigot or hose bib or whatever you call it on the OUTSIDE so we have faucet on outside of trailer from the water tank just inside....(does that make sense?)
I had this set up on my last trailer and I know my very handy husband (contractor skills) can install the water tank, but how hard is it to install the BATTERY? We want to use a sure-flo-pump because I like the pressurized water to use for bathing (horses and humans) and I want the pump and interior lights to be able to run off the new additional battery.
Can a really handy husband do this? Again - I know we can do the water tank install, even cutting the little hole and putting the bit of plumbing to create the outside spigot, but I just don't know about the BATTERY. It seems we'd have to hook it into the electrical system somehow. He does electric work on our house....I bet if he looked at one for reference he could.
But thought I'd ask YOU GUYS!!! Can this be done by a handy person with contractor-skills? (he remodels houses and does a ton of DIY including plumbing and basic electric)
Posted 2013-05-17 4:33 PM (#152098 - in reply to #152096)
Subject: RE: Installing corner water tank, pump, 12v/deep cycle marine battery - how hard is it?
If DH can wire a house, a battery, pump & switch should be no problem.  One caution ... Install the battery outside the trailer or properly vent it.  The battery will produce hydrogen gas.  Remember the Hindenburg !
Fancy That
Reg. Jan 2012
Posted 2013-05-17 5:49 PM (#152100 - in reply to #152096)
I think it's the battery that worries me. My husband isn't an electrician or anything. Maybe we'll just DIY the water tank, water pump, plumbing and let the trailer shop install the battery?The $450 was labor only. I've been shopping for all materials and the materials alone would be another $400. So we are talking at least $850! Ouch :)
Posted 2013-05-17 9:18 PM (#152101 - in reply to #152096)
The battery installation is actually fairly easy with a basic electrical aptitude. From your truck will be a hot wire that most probably supplies the interior lighting. The trailer's pig tail from the plug usually ends at a terminal strip, underneath the goose area or sometimes inside the trailer. If you splice into that terminal, you'll have a hot wire that will run to your B+ battery terminal. The battery ground terminal (-) will be grounded to the trailer's structure.
The battery should be located in an enclosed battery box and as was previously stated, should be externally vented, by direct holes or vent piping. There should be a securing system to locate and hold the battery in place within the box.
From the B+ terminal, you should install a 15 amp breaker and a 14 AWG stranded wire leading to your water pump. The pump will have two leads, one a hot wire and the other a ground. The B+ wire goes to a single pole, single throw on/off switch, and then to the hot side of the pump. The other wire is grounded to the trailer's structure.
When you install a vertical water tank, the supplied nylon straps have had many complaints about properly securing the tank in place. Many of these straps have been replaced by gas tank stainless straps, secured in place with SS sheet metal screws and padded using foam pipe insulation. It is also advisable to build a small platform onto which the tank will be supported off the floor. The will allow you to install an interior spigot by which you can both fill a bucket and drain the tank, without having to use any outside plumbing.
Fancy That
Reg. Jan 2012
Posted 2013-05-17 11:09 PM (#152110 - in reply to #152096)
Thank you Gard. I'll show this thread to my husband for sure and see what he thinks.
I also read the same poor reviews on the nylon straps that "come with" the tanks. We'll use something stronger....whether it is the metal straps used on hot water heater tanks or just heavier-duty tie-downs.
One thing my husband doesn't do is welding (we both wish we could weld...such a handy skill) so I'm not sure we can attach the battery box/platform thing (unless it can just be bolted/screwed on....at the front of the gooseneck, outside)
Posted 2013-05-18 9:36 AM (#152115 - in reply to #152110)
http://tweetys.com/batteryboxestraysandholddowns.aspx
http://www.thefind.com/electronics/info-rv-battery-tray
http://www.nocousa.com/pdf/Noco-Catalog-Battery-Storage.pdf
trot-on
Reg. Dec 2009
Posted 2013-05-18 7:21 PM (#152120 - in reply to #152096)
The typical corner water tanks have the spigot at the bottom, so they gravity flow out to a bucket sitting on the ground. Just curious about the need for the "pump".
Fancy That
Reg. Jan 2012
Posted 2013-05-18 10:51 PM (#152124 - in reply to #152120)
Originally written by trot-on on 2013-05-18 5:21 PM
Trot On - I had this set up on my last trailer and love it with the pump because I mostly use it to wash the horses, but also for the tankless on-demand water heater for bathing/showering (for humans when camping) The pressure is really great for washing and I even rinse my trailer immediately/instantly if a horse pees in it, with this. Like having a pressure washer all the time :)
Fancy That
Reg. Jan 2012
Posted 2013-05-18 11:12 PM (#152126 - in reply to #152115)
Thanks, Gard! These are helpful links.
QUESTION - the battery in my old trailer was just in a plastic box like the ones in the links,and it was in the dressing/tack room. But I understand they should be vented and I see tons of them on the front/outside under the gooseneck. If I put it there, do I just buy this plastic battery case, plus some sort of metal shelf/rack? Or should I get the really expensive metal battery box?
Posted 2013-05-19 12:11 AM (#152127 - in reply to #152126)
The easiest way is to mount a plastic box with a vent like this one inside the forward tack area:
http://www.rvpartscountry.com/RV-Batteries-Fans-Accessories_c_317-4-1.html
The box can be placed under a step or inside storage areas and vented to the exterior. If the battery is going to be located on the outside of the forward bulkhead, a strong bracket will have to be fabricated. The battery can weigh up to ~50# and the bracket should be strong enough to handle double or even triple that amount. If you traverse rough back roads, the stronger the bracket, the better.
Find a fab shop and have one made of the same material as your trailer, IE steel or aluminum. Use the appropriate hardware to secure the bracket, bolts, locking nuts and large skin washers. Do not use sheet metal screws. The battery can be protected from the elements inside a plastic box, mounted onto the battery's platform.
Fancy That
Reg. Jan 2012
Posted 2013-05-19 9:22 AM (#152142 - in reply to #152096)
Thanks again, Gard. Turns out my last trailer with the battery inside in the tack room, wasn't "vented to the outside". It just sat under my saddle rack. Is that really bad?
thanks for the link the battery box with vent. I think it saves space inside (I only have a 33" short wall dressing/front tack room) to put it on the outside bulkhead under the neck. But like you said, sounds like a job for professionals - to ensure the brackets and platform are really solid enough to carry the battery
Slackdaddy
Reg. Mar 2013
Posted 2013-05-20 5:10 PM (#152174 - in reply to #152096)
450.00,, thats all?
That shop, electrical, employees, taxes aint free,, remeber 52% of that bill is going directly to the government.
Fancy That
Reg. Jan 2012
Posted 2013-05-20 10:47 PM (#152183 - in reply to #152174)
Originally written by Slackdaddy on 2013-05-20 3:10 PM
450.00,, thats all?
Yes, for labor only. Materials are expensive and I'd be paying for that either way. I'm trying to save $500 in labor by DIY (via husband :) Materials add up to over $400. That's $900 project that I can cut in half if we can do some of this ourselves.....
Renee'
Reg. Mar 2013
Posted 2013-05-27 11:53 AM (#152271 - in reply to #152096)
I have a DIY dad.  He and I just installed all of these items in my trailer.  Yes, you can do it.  If you are haven't bought you instant water heater and pump, I highly recommend the Marey brand.  I just bought the instant water heater, with the shower head and water pump on ebay for $186.  We also installed the corner water tank, it's very simple. I don't recommend using the straps that are sent with the tank.  We used plumbers tape (metal stuff with holes) which we encased in pipe foam insulation to protect the tank from the metal strap.
Fancy That
Reg. Jan 2012
Posted 2013-05-29 9:50 PM (#152327 - in reply to #152096)
Thanks Renee! Did you and your dad install the deep cycle battery, too? Did you put it under the gooseneck outside? I just don't know how to attach a very strong bracket or platform to the outside bulkhead wall under the GN.
I already bought the same water pump as my last trailer had - a Shur-Flo and switch. It will be connected to the corner water tank.
Seperately, I'm getting something like this Eccotemp portable Tankless Water Heater, which we'll use mostly at the barn (at home) and occassionaly take camping if we are really boondocking.
http://www.eccotemp.com/eccotemp-l5-portable-tankless-water-heater/
Edited by Fancy That 2013-05-29 9:52 PM
