      Location: Rocky Mount N.C. | Should be on the serial number data plate mounted on or near the left front of the trailer where the gooseneck meets the main box. Or somewhere on the tongue area, maybe the left/drivers side. If the trailer has 5 lug 15" wheels, it probably rated at 7000#. If it has 6 lug 15" wheels it may be as much as 9000#. Chances are you got two 3500# axles rated at 7000# for the pair, mfg. would rate the trailer at 7000# |
