       Location: western PA | If the trailer will be stored, an uneven pad won't hurt anything. If the LQ and its equipment will be used during storage, a more level area will alleviate any appliance problems. Before you haul any gravel, you might consider RV jacks that are used to level various types of RVs. Another consideration is a small hydraulic jack and some concrete blocks, to temporary level the trailer while its in storage. If the trailer is going to be often moved, the only reasonable recourse is to have a fairly level pad. |
