lunde lift hydraulic jack repair
mud_dog
Reg. Dec 2004
Posted 2013-02-17 12:09 PM (#149961)
Subject: lunde lift hydraulic jack repair
Jack lifts great won't lower any suggestions.
Posted 2013-02-17 1:05 PM (#149962 - in reply to #149961)
Subject: RE: lunde lift hydraulic jack repair
Does the pump motor run in the lower position? If so there may be a check valve that is stuck, maybe some ice in the system... Is the hydraulic fluid at the proper level?
Don't know much about a Lunde system, think they went out of business in 2006. Picture of a Lunde system below.
mud_dog
Reg. Dec 2004
Posted 2013-02-17 3:42 PM (#149964 - in reply to #149961)
It just clicks when trying to lower. What position is the jack to see if it has enough fluid.
yeehaw
Posted 2013-02-17 7:06 PM (#149969 - in reply to #149961)
My first guess would be a reversing relay that is pulling in but not making a electrical contact I do think that the hyd. motor runs 2 directions 1 to raise and 1 to lower, if it's clicking I'd first look for bad or loose connections, you should have a power relay/switch somewhere that changes the motors direction of rotation. I think the click you are hearing is the relay trying but due to a problem it's not sending the voltage to the motor.
mud_dog
Reg. Dec 2004
Posted 2013-02-17 7:28 PM (#149970 - in reply to #149961)
Thanks
justgurn
Reg. Oct 2010
Posted 2013-03-01 3:46 PM (#150283 - in reply to #149970)
Mud_dog,
You have the same jack that I have on my trailer. The jack operates on a positive pressure meaning the pump lifts and the pump lowers. There is a manual pump on the top of the unit along with a valve to switch directions. I would guess one leg of the solenoid gave up on you as mentioned in a prior thread. To check the fluid level the leg needs to be in the raised position. The reservoir is about 3/4 full when full.
