      Location: Rocky Mount N.C. | You talking about one of these...? I know nothing about them... First time I've ever seen a "NO MAINTENANCE" trailer...
All Aluminum Trailer with Extra Features! 2 Saddle Racks & 4 Bridle Hooks in the Front Under the Mangers! Two Deluxe Aluminum Feed Mangers in Front! Hinged Door Between the Horses & the Tack Compartment was an Extra! Keeps The Horse Manure in the Back! Deluxe Features Abound in this Hi-Line Trailer! RV Style Front Walk-In Door with Sliding Window w/Screen! Deluxe Horse Logos on the Sides! All .050 Thick White Aluminum Metal Walls are Super Thick & Strong Inside & Out! Aluminum Main Frame and Aluminum Inside Structural Frame of All Tubing Metal. Tandem 3,500 lb Dexter Torsion Axles for a Smooth Ride! Brakes on Both Axles! 15" Steel Belted Radial Tires with Mounted Spare. Wheels are 15" Silver Steel with Deluxe Chrome Wheel Covers! 7ft 4" Tall Inside. Ramp Door with Easy Lift Stainless Steel Spring Assist Along the Ramp Bottom! Removable Top Doors Above the Rear Ramp for Summer Hauling! Rear Side Windows Slide Open for Ventilation and Have Screens. Two Aluminum Roof Mounted Vents Side Drop Down Windows with Aluminum Flip Down Safety Bars! 2 5/16" All Steel Bulldog Hitch! Treated Wood Floor Underneath the 3/4" Thick Rubber Mats! Aluminum Side Steps for Convenience & Protection! LED Tail Lights Look Fantastic! Aluminum Padded Center Divider is removable! Steel Tongue Jack with Sand Foot! 7 Pin Light Connector & Battery Break Away Kit. Interior 12 volt Dome Light in the Front of the Trailer. This is a Beautiful No Maintenance Trailer! This Trailer Weighs Only 2,300 lbs! Made by Trailers USA in Ocala, Florida. Are you by chance looking at this one...?? http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=423760 |
