sequoia or tundra
gryffncruz
Reg. Jan 2013
Posted 2013-01-13 9:41 AM (#149299)
Subject: sequoia or tundra
I know trucks are the best, but as mom with kids and one vehicle, debating looking at the sequoia as an option over crew cab. Same platform I believe?
Posted 2013-01-15 11:15 PM (#149365 - in reply to #149299)
Subject: RE: sequoia or tundra
1000500100100100252525
the real question is how much can the car pull what is the weight of the trailer loaded I own a tundra and it works great gooseneck stock with draft horse
Edited by loveduffy 2013-01-15 11:16 PM
Posted 2013-01-15 11:46 PM (#149366 - in reply to #149299)
Originally written by gryffncruz on 2013-01-13 9:41 AM
TOYOTA SEQUOIA - 2013
Curb weight (lb.) 5730
Gross Vehicle Weight Rating (GVWR) (lb.) 7100
Gross Combined Weight Rating (GCWR) (lb.) 13,600
Towing capacity [4] (lb.) 7400
[4]Before towing, confirm your vehicle and trailer are compatible, hooked up and loaded properly and that you have any necessary additional equipment. Do not exceed any Weight Ratings and follow all instructions in your Owner's Manual. The maximum you can tow depends on the total weight of any cargo, occupants and available equipment. Calculated with new SAE J2807 method.
liv to ride
Reg. Jul 2007
Posted 2013-01-19 3:16 PM (#149413 - in reply to #149365)
I am quite sure that most people would agree with the statement , that it is not what the vehicle can pull, but what it can safely stop.
Posted 2013-01-19 6:21 PM (#149420 - in reply to #149299)
They are pretty much the same platform.  So the real question become, what option does the Sequoia have. vs the tundra
Assuming they are equally outfitted option wize.  Then either will perform the same.
