1/2 ton vs 3/4 ton
NDHorseman
Reg. Jan 2013
Posted 2013-01-09 7:52 PM (#149224)
Subject: 1/2 ton vs 3/4 ton
I'm looking to upgrade to an aluminium 2 horse with basic living quarters.  I have a Sundowner in mind with 5' LQ that has the following:
Axle Size 5,200 LB
Approx Weight 5,800 LB
GVWR 10,400 LBS
I currently have a 1/2 ton Silverado.  My problem is that I can't afford to upgrade both my pickup and trailer right now, so I am checking out the option of light LQ trailers that I could pull with my 1/2 ton.  Any comments/advice would be appreciated.  Thanks for the help!
Posted 2013-01-09 9:00 PM (#149225 - in reply to #149224)
Subject: RE: 1/2 ton vs 3/4 ton
Towing capacity varies by the model and extras.
2006 Silverado 1500 Towing Capacity: 3,800 - 10,300 lbs.
2007 Silverado 1500 Towing Capacity: 4,300 - 10,800 lbs.
2008 Silverado 1500 Towing Capacity: 4,300 - 10,500 lbs.
2009 Silverado 1500 Towing Capacity: 4,400 - 10,700 lbs.
2010 Silverado 1500 Towing Capacity: 4,400 - 10,700 lbs.
2011 Silverado 1500 Towing Capacity: 4,400 - 10,700 lbs.
2012 Silverado 1500 Towing Capacity: 4,400 - 10,700 lbs.
2013 Silverado 1500 Towing Capacity: 4,400 - 10,700 lbs.
You need to confirm your rear axle capacity for your truck.
NDHorseman
Reg. Jan 2013
Posted 2013-01-09 11:23 PM (#149226 - in reply to #149224)
I have the 2011, so the trailer would max out before the pickup, I guess my main concerns would be how hard it's going to pull, and how well the pickup handles the weight at those upper ranges. Does anyone have experience pulling a similar trailer with a half-ton?
rmax
Reg. Feb 2009
Posted 2013-01-10 5:20 AM (#149232 - in reply to #149224)
I have the same truck,with 2 horses you will run out of payload before you have to worry about anything else.These trucks pull pretty well with the 6 speeds but pin weight is a killer for 1/2 tons.If you was to stay legal get accurate pin weight otherwise you might be leaving your passengers at home.
NDHorseman
Reg. Jan 2013
Posted 2013-01-10 12:35 PM (#149243 - in reply to #149224)
Thanks for the help guys!
The dealer estimated about 25% of the trailer would be tongue weight, which once loaded would put me right near the upper limit of the payload capacity of my pickup.  The trailer is exactly what I'm looking for at a price that I'm happy with.  I just don't want to buy a trailer that's too heavy for my pickup.
RTSmith
Posted 2013-01-10 2:39 PM (#149245 - in reply to #149224)
Estimated 25% tongue weight. That is the pat number for a GN that was built ideally. If this trailer has an escape door, you may be more towards 40%.
See Gards thread recently about pulling a 2H GN with shortbox trucks.
Then order you the Sundowner without an escape door and the axles shifted forward. You'll love the trailer on your current truck. JMHO
