Location: Colfax, WI | I am having trouble finding a replacement cover for an exterior speaker on our '02 Bison Alumasport w/LQ. I'm attaching a photo - if anyone can help out with a source, I sure would appreciate the help!Thanks, Nan |
        Location: North Carolina | Might be easier and cleaner to just get two new covers. The covers will match instead of a new and old cover. Take the old cover off and measure the screw hole spacing and outside diameter of the cover. Then, purchase new covers according to your measurements. If the old screws aren't long enough, new stainless steel screws can be had at Home depot or Lowes hardware. |
       Location: western PA | http://www.parts-express.com/cat/steel-speaker-grills/323 http://compare.ebay.com/like/251034358243?_lwgsi=y<yp=AllFixedPriceItemTypes&var=sbar |
    Location: Lockport, Illinois | I would either call the manufacture of the conversion, it could be Bison, and find out the manufacture of the speaker or remove the speaker and on the back there should be the name of the manufacture. Then contact them and order some replacement grills. I looked at various RV and marine suppliers and surplus dealers and couldn't find anyone selling white plastic grill covers. Good Luck. |
Location: Colfax, WI | Great idea to pull these off to see more info - I hadn't thought of that. These are plastic, it will be great to replace with metal ones. I'll paint them if necessary.
Thanks for the advice! |
