living quarter conversion
teamroper25
Reg. Dec 2012
Posted 2012-12-28 2:49 PM (#148993)
Subject: living quarter conversion
Hello everyone!!! I have a 16' steel stock trailer and i was wanting to put in a weekend package with maybe a 4' wall. The trailer has nothing in it now how hard and how much trouble would this task be to do. Were do i start.  thanks in advance
Phoresic
Reg. May 2010
Posted 2012-12-29 10:07 AM (#149007 - in reply to #148993)
Subject: RE: living quarter conversion
500
Phoresic
Reg. May 2010
Posted 2012-12-29 10:14 AM (#149009 - in reply to #148993)
500
How easy or hard really depends on how nice you want it to be.  You can do something simple that isn't too hard or expensive.  A good idea is to go to the photo gallery on this website and look at pictures.  Go back through a lot of threads here and you'll find great photographs and ideas.  If you want something that is minimalist, just do some insulation and paneling, a shelf for a microwave, a sink, a porta potty, a cowboy shower, and a sleeping surface.The Todd Redwrench site is pretty much the standard first step.
TPenning
Reg. Feb 2008
Posted 2013-01-05 9:39 AM (#149130 - in reply to #148993)
I had a steel trailer once, and the previous owner had put in a home made dividing wall to make an LQ.  He did it in wood, and then on the horse side installed a removable chest bar (it was a straight load) so the horses had head room and no contact with the wall.
In the LQ area, I sistered 1" x 1" to the studs, which are never equally spaced along the trailer wall so be prepared to measure, measure, measure.  Styro insulation between the studs, and good one side 1/2" plywood for the walls, prepainted BOTH sides before install.  Did the same treatment on the ceiling, but for the curve between the top of the wall and the ceiling we cut strips of a plastic board - I can't recall the name but it comes in 4' x 8' sheets and is commonly used in barns around here to sheet the base of the walls.  It's quite flexible and we only had to bend and tuck it into place.  All the wiring for the trailer lights ran behind this, so it was easy access and looked really good too.
The floor was done in linoleum, built an L-shape bench with storage below that converted to a bed, and had a removable triangle shaped table that stood in front of it.
The walls of this space were 10' long, and since I had no tack room, 4 saddle racks were installed on the dividing wall.  All this and still held a family of 4!
We did no plumbing, so can't help you there.  One show we went to I remember it snowed and we were in there pretty toasty with only a space heater that we had to keep shutting off so we wouldn't bake.
skippyvcu
Reg. May 2006
Posted 2013-01-05 1:13 PM (#149135 - in reply to #148993)
This web site has a lot of good pictures and ideas.
http://todd.redwrench.com
terri s
Posted 2013-01-06 8:07 AM (#149151 - in reply to #148993)
500100100100
Not to hijack this thread, but I have this fantasy about a new (to me) trailer and would like to do my own weekender. Should I look for a particular axle weight to support the LQ or is that relevant?
Posted 2013-01-06 10:28 AM (#149153 - in reply to #148993)
A friend of mine bought the same trailer I have without a weekender package. (Exiss 4' weekender Sierra) My trailer weighs about #900 more than his. We built a weekender LQ in his trailer, copying the floor plan and accessories that mine have. We installed full plumbing, fridge, cabinetry, water heater, enclosed bathroom, insulated floor, walls, ceiling etc. We did eliminate the installation of a gray tank, using a black water tank for everything.
The total weight gain was again about #900. Almost all of this weight is near the front pin of the trailer, with less being placed upon the axles. A standard guess about pin weights on GN trailers is 25% of the total. This actually greatly varies by dressing room lengths, equipment carried, ST loads VS SL, and importantly, axle placement. The addition of a LQ skews these figures considerably. The pin weights can then be almost 40% in some circumstances.
If you take your axle capacities and add 25%, you will end up with a theoretical max carrying capacity. If you subtract the weight of the trailer added to the loads, hopefully you will end up with a figure that is less than its max capacity. This is commonly referred to as a reserve capacity. The higher the reserve, the less stressed the trailer's structure and running gear will encounter.
Example; a trailer is built with 2 3500# axles giving a max of 7K capacity. If the pin supports 1750# of that, you have a maximum possible capacity of #8750. If you carry three horses and gear weighing a total of 3500#, and your trailer weighs 4000#, you will have a reserve of 1250#. Adding a LQ will lower the reserve capacity. By how much? Only by physically weighing the truck and trailer can the actual weights be known. There are just too many variables.
Some trailers with elaborate LQs, are built with almost no reserve capacity. If you hear of a 17500# trailer being supported by 7K axles, you will understand that the manufacturer is depending on the pin, to aid in carrying the load. This trailer will have little or no reserve capacity. You will hear of frequent axle problems and tire blow outs. The various components are stressed to their maximum and will eventually fail. A trailer built with a reserve capacity, will provide a longer trouble free life span.
Posted 2013-01-06 8:25 PM (#149166 - in reply to #148993)
Originally written by teamroper25 on 2012-12-28 2:49 PM
It depends just how much weight the trailer designers of that stock trailer expected the pin to be able to handle...trying to add an LQ area may unbalance the trailer...:(
