Towing with a Roadtrek?
ILdonkgal
Reg. Nov 2012
Posted 2012-12-03 9:37 AM (#148692)
Subject: Towing with a Roadtrek?
Has anybody used a Roadtrek 170 camper van as a tow vehicle for their horse trailer?  If so, how did it perform and how big of trailer/how many horses did it pull comfortably? thanks for any advice..
Posted 2012-12-03 11:07 AM (#148693 - in reply to #148692)
Subject: RE: Towing with a Roadtrek?
It's a van right? 1/2, 3/4 and 1 ton chassis?
RTSmith
Posted 2012-12-03 2:11 PM (#148698 - in reply to #148692)
They used a lot of GM & Dodge chassis. Most would be labeled the G20/D250 series, but they were not the same as a truck of similar nomenclature (most had 15" tires and 5 lug wheels). You need to identify your actual chassis by year, make, & model- and then compare the weight of the coach as loaded to go camping against the chassis manufacturer's capacity and towing specs.
