Help with Sundowner electrical
DoubleBranch
Reg. Jul 2012
Posted 2012-10-19 8:39 PM (#147778)
Subject: Help with Sundowner electrical
On just my third trip with 2000 Sundowner LQ. All electrical outlets not working but the two GFIs don't appear to be tripped. Microwave and TV also out, everything else OK. Check breaker and seems to be OK. Doesn't look like all this stuff on a single fuse. What am I missing?
Posted 2012-10-20 8:23 AM (#147788 - in reply to #147778)
Subject: RE: Help with Sundowner electrical
Need more information to help.  Are you on a generator or utility power?  What else works ?
DoubleBranch
Reg. Jul 2012
Posted 2012-10-20 8:16 PM (#147802 - in reply to #147778)
Thank you for reply. Turns out the campground outlet wasn't working at all. I was running strictly off the solar powered battery and not enough juice anything other than lights. Live and learn! Switched to another outlet and everything fine. Do have question though. When hooked to city water should I still use pump or not.
cajunmuleman
Reg. Oct 2011
Posted 2012-10-21 8:20 AM (#147807 - in reply to #147778)
When hooked to city water the pump is not used. The pump is only for use when usung water fron the holding tank.
