Two horse trailer for draft horses
bettygottberg
Reg. Oct 2012
Posted 2012-10-18 2:19 PM (#147746)
Subject: Two horse trailer for draft horses
What do I need for a two horse BP for
two draft horses? one weighs 2000 lbs the other
1800 lbs. I need it for short trips, as I have a large
4 horse commerical trailer?
Talk to me Someone LOL!
cajunmuleman
Reg. Oct 2011
Posted 2012-10-18 4:47 PM (#147749 - in reply to #147746)
Subject: RE: Two horse trailer for draft horses
One thing you need is a BIG TRUCK. Your horses weight more than some peoples trailer LOL
siseley
Reg. Jul 2006
Posted 2012-10-19 9:17 AM (#147766 - in reply to #147746)
I would look to a dealer in stock type trailers, and one that is aluminum. (Dixie comes to mind, 877-694-5665). Then look to find one that is both tall enough, and probably will need to be a straight load, so you can get them comfortable. As the other poster has said, you will need to use your big truck to pull, and hope you have good luck finding what you need.
jim bob
Reg. Jan 2008
Posted 2012-10-19 10:02 AM (#147768 - in reply to #147746)
We have had customers in the past use straight loads that are 7 wide, and 7'6" tall. Most of thiese will have a 7' length stall (from chest bar to butt bar, and 3' of head area. You can always order one and request more footage added. A bumper pull stock with a gate placed about 2/3 of the way forward in the trailer works well. Make sure you get a trailer with 5200# or 7000# axles under it, w/ 16" 10 ply rubber. When hauling drafts; you will need height, width, strong floor system and heavy axles and tires.
donnat
Reg. Feb 2005
Posted 2012-10-19 10:49 AM (#147770 - in reply to #147746)
Sent you a private message
adeberti
Reg. May 2007
Posted 2012-10-19 11:23 AM (#147771 - in reply to #147746)
I have one draft about the same size as yours: we have a 3 horse GN slant with 50" wide stalls: they are adequate, optimally a few inches bigger would have been better.If they play nice with each other i would check for a stock type (although i hardly see them at 7'6"). Another option is to get a regular 3 horse slant and take out the first divider for the first horse and put the other in the last stall as it usually a bit bigger. (you can also take out all the divider and reweld the hinges right int he middle for two big stalls)I guess a lot depends on your price range
mary5ken
Reg. Oct 2012
Posted 2012-10-19 11:46 AM (#147773 - in reply to #147746)
Hello,
I have a 17-3 Hanoverian that I have towed with my 4 Star bumper pull.  He weighs upwards of 1400 pounds and with another very large horse in the trailer, I have had no problem pulling them with a Yukon Denali or a Ford F 150.  If you are interested, I just listed this trailer for sale last week.  It's been used only a handful of times as I've switched barns and my new barn does all the shipping for us.  Take a look.  It's a 2008 and compared with a new one, there's a lot of savings.  I'm in IL.
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=416016
Posted 2012-10-19 5:09 PM (#147776 - in reply to #147746)
Originally written by bettygottberg on 2012-10-18 2:19 PM
What do I need for a two horse BP for two draft horses? one weighs 2000 lbs the other 1800 lbs. I need it for short trips, as I have a large 4 horse commerical trailer? Talk to me Someone LOL!
Check on the Hawk website. They build a XXL trailer, and will probably custom build whatever you want. Myself, if I had two horses that size, I would be searchig for a stout, heavy duty built all aluminum stock trailer, something suitable for hauling cattle. Some of these two horse trailers would split at the seams if a couple 2000# draft horses wanted to get a bit restless..!!
Posted 2012-10-19 10:50 PM (#147780 - in reply to #147776)
Originally written by retento on 2012-10-19 5:09 PM
The Hawk custom is good and if the Op is in the east...Kingston used to make (special order) a two horse straight load Windsor model with extra height and bigger axle option...that could transport 2 18 hand percherons without problems...
bettygottberg
Reg. Oct 2012
Posted 2012-10-20 4:53 PM (#147794 - in reply to #147766)
Thank you so much for your info.
....Sincerely Betty
bettygottberg
Reg. Oct 2012
Posted 2012-10-20 4:55 PM (#147795 - in reply to #147768)
Thank You so much for the info. Everyone has been so
helpful!!!!.........Betty
bettygottberg
Reg. Oct 2012
Posted 2012-10-20 4:59 PM (#147796 - in reply to #147773)
Thank you for the info. I am looking for
something less than that price.
Sincerely... Betty
Posted 2012-10-21 10:54 AM (#147812 - in reply to #147746)
1000500100100100252525
I have one draft horse and I got a  eby stock aluminum trailer he loves it
Edited by loveduffy 2012-10-21 10:57 AM
