| Ok- I just closed my drop down windows on my 99 S&H Horse trailer, but something extra went up with the window. The little rubber bumper that is SUPPOSED to stay on the body of the trailer below the window cracked, came off the body and stayed on the "Knob" that is on the outside of the window when I put it up.What is the name of the "bumper" piece and does anybody know who sells them. It appeared to be a bit dry rotted, although I did grease them last year just because. And if I replace the one, I might as well replace all three of the bumpers. I can call S&H, but when I needed information about a wiring diagram for the plug on my trailer they seemed clueless at the factory. Apparently they don't keep records of how they wire their trailers or what color wire they use. 8 Hours later my trailer was wired up the hard way. So not much faith in the company themselves. I'm sure the experts here know the name of this part I am needed. |
      Location: Rocky Mount N.C. | Something like this...? http://www.horsetraileraccessorystore.com/door_stops.htm |
  Location: Wright City, Mo | Try this place. Have been able to find what I need from them in the past. lhttp://www.horsetraileraccessorystore.com/index.htm |
| Its a lot like that, but with a deeper inset part. I've got an email in to them as well :) |
    Location: Lockport, Illinois | This is what you are looking for. Any large trailer dealer should carry them.Silent Door Holder- Rubber Replacement Insert onlyhttp://www.horsetraileraccessorystore.com/door_holders.htm |
| I've had good luck with S&H parts using textrail.com. They are somehow associated with, or part of, S&H. They have been quite helpful 2 different times when I needed replacement parts. |
        Location: North Carolina | Originally written by BigT on 2012-08-29 2:31 PM This is what you are looking for. Any large trailer dealer should carry them.Silent Door Holder- Rubber Replacement Insert only http://www.horsetraileraccessorystore.com/door_holders.htm[/QUOTE] The site Big T posted has several types of rubber bumpers. Look at the type called door hold back : That's what was used on my drop-down windows. |
 Location: Close to the Heart of The Great Smokey Mtns. | Was the holdback white or black.check out this link, http://www.sundownerparts.com/.sc/ms/cat/Trailer%20Body%20Component...
There are some other holdbacks in this section as well. |
 Location: Close to the Heart of The Great Smokey Mtns. | Look under Trailer body components, Holdbacks. |
