 Location: Southern Virginia | So I'm in need of some new tires, and it's been a while...I purchased this trailer used, last year with LT tires on it. My last tire I had going in Carlisle Trailer tires, which I was pleased with (didn't have it much longer after I bought new tires for it). So I have two questions, what's the best quality trailer tire for the money out there? And how do I tell what ST size I need? Right now it has 7.5-16LT, Load Range D tires.....Any help here?Thanks! |
      Location: Rocky Mount N.C. | What size is listed on your trailer's data plate/serial number tag...? |
 Location: Southern Virginia | 750 x 16 GY8 BoltThanks |
      Location: Rocky Mount N.C. | Originally written by endurance_racer on 2012-08-21 1:32 PM
750 x 16 GY8 BoltThanks 750 x 16 GY8 Bolt is what's listed on the data plate mounted to the trailer's frame...? What's the size and load range is listed on the data plate? Don't care what's on the trailer now, want to know what was installed at the factory when the trailer was new. Then go from there. A 750 x 16 may come in a load range ,"C", "D", "E", "F", "G", etc.... 6, 8, 10, 12 and 14 ply.... |
 Location: Southern Virginia | That is what it says on the plate...Nothing else. I will try to get a hold of Bee today, see if I can find something out. |
 Location: Southern Virginia | Got a hold of the nice folks at Bee Trailers. They looked up the trailer, said that it needs ST 235 80R 16. Load Range E. Now to find some quality tires--seems daunting from everything I've read. |
      Location: Rocky Mount N.C. | Go with a name brand American made LT235-85x16 lrE radial truck tire. Forget the "ST" tires, especially a Charlisle brand... You'll "BEE" glad you did... Uniroyal Laredo HD/H BF Goodrich Commercial TA Goodyear Wrangler HT Michelin XPS Rib These are just a few.... |
Location: Toronto, Ontario | About the only ST tire that I get a good review on is the Goodyear 614 tire. I don't want to put LT tires on my trailer. I haul three horses each weekend and probably put the better part of 15,000 to 20,000 miles per year on the trailer. With three horses on the trailer would weigh the better part of 11,000 lbs. I don't think LT's are rated to carry that kind of weight. From Toronto, Ontario, Canada, so I am looking at the better part of $1,600 to $1,800 for four new tires for my trailer. If anyone else has a good recommendation that is as good as the 614's but at a better price I would love to hear about it. But the best, most reliable tires are the prime requirement. Have blown two tires on the road before with horses on board and both have gone suprisingly well, but I can see lots of very bad scenarios as well, and don't want to live one. Thanks |
       Location: western PA | Suggest that you do a "SEARCH" under tires, and read about the many people who have upgraded their tires from the STs to LTs and why. Purchase any of the brands in Retento's list, and you will have a safe and long lasting tire ownership experience. |
Location: Toronto, Ontario | Thanks. I have been reading all the tire search threads. Also have some friends who have ST and LT tires. Like most things in the horse business you get lots of debate. Apparicate the feedback. |
   Location: Barnesville, Ga. | I upgraded from the Goodyear 16" 14ply to a 19.5 inch wheel and tire combo. I have been very happy with the combo. The wheel is made by Vision Wheel it is aluminum. I am running a Kelly Springfield (Goodyear made) tire and have had no problems. I probably have 5+k miles on them with zero issues. They are not that much bigger. A 245-70-19.5 is 9.6" wide x 33" tall. A 215-75-17.5 is 8.3" wide x 30.6" tall. A 225-70-19.5 8.8" wide x 32" wide. A goodyear G614RST 235-85-16 is 9.5" wide x 30.7" tall. I started to go the 17.5 route but soon realized that was an odd combo. Not that many roadside service people carry that size, and not that many manufacturers make a 17.5. I went with the 19.5 mainly because there was lots of suppliers of this size tire and most roadside service companies stock a 19.5 for commercial use. I only got a little over 2 years use out of my goodyears. Goodyear was very good to me with the warranty claims as the tire is warrantied for 3 years and they did pay for damages to the trailer as a result of the blow outs. That was whay I went back with a Goodyear product. I also installed a tire pressure monitor system from Truck System Technologies. It was $250 for 4 sensors and a monitor. It monitors pressure and temp of air in tire. I have been real pleased with the setup. |
   Location: Barnesville, Ga. | Seems like the new wheels were about $200 each and the tires were about $225 each. Seems like the Goodyear 16" locally were about $380 each and in about 2 years I would be back to buying more tires. I am hoping to get 4 years out the 19.5's. |
       Location: western PA | "With three horses on the trailer would weigh the better part of 11,000 lbs" With that weight and considering aprox 25% or more will be on the pin, you will not need a "G" rated or over sized tire. An "E" range 16" tire will suffice.
Edited by gard 2012-12-11 2:48 PM
Location: Toronto, Ontario | Thanks I was wondering if you deducted any amount of trailer weight that would be on the hitch. It makes sense to do so, but was not sure of the number. This is not as bad as calculating power usage for generators :), but who knew I needed to become an engineer when I got into the horse world. |
