Have you checked the body caulking around the vent frames? Is the vent cover installed correctly in place? Does it seat well into the frame? I would suspect the vent cover as being a possible cause, along with any roof protrusion exiting on that side of the trailer; vent, running light etc. The fridge vent covers do a pretty good job of keeping water out. Recently I power washed our trailer @2800 PSI and hit the vent side on. Checking the inside space afterward, I found no water had entered the area. Water can creep a long way from its source. I would check everything above the rear of the fridge on that side of the trailer, several feet forward and aft. Look for any cracked body caulking as well. |
