Replacing rubber side mats
Meme_melissa
Reg. Aug 2012
Posted 2012-08-17 1:25 PM (#146413)
Subject: Replacing rubber side mats
My husband and I bought a 2 horse trailer last year. We want to add rubber mats to the side of the trailer. We bought 3/16 th rubber for the side. We are thinking of using 1/2 in or smaller dry wall screws with washers. We were wondering if this is the best way or if we should try something different? Thanks in advance.
Posted 2012-08-17 3:10 PM (#146415 - in reply to #146413)
Subject: RE: Replacing rubber side mats
http://www.horsetraileraccessorystore.com/fasteners.htm
Look for the "TEK" screws in this website.
Do not use common drywall screws. They are weak and brittle.
whitewood
Reg. Jun 2009
Posted 2012-08-17 3:53 PM (#146416 - in reply to #146413)
3/16 aluminum pop rivets w/large 1/2"head
trot-on
Reg. Dec 2009
Posted 2012-08-17 7:52 PM (#146418 - in reply to #146413)
I used 3M adhesive in a spray can. Hi-Strength, green can. it was recommended by the local trailer repair shop. This stuff was awesome, and I never had to use a single screw on my wall mats. Tricky to brace in place as it dried. Wedged 2x4's up onto mats.
henrynva
Reg. Nov 2011
Posted 2012-08-18 1:46 PM (#146427 - in reply to #146413)
I added side rubber mats by using Liquid Nails and 2x4's. Do both sides at the same time with 2x4's uprights with a cross 2x4 wedged in-between. Then use black silicone sealer around the edges to prevent water entrance.
