Location: Lawrence, Kansas | Hello everyone. I purchased a Titan Renegade III Gooseneck 2 horse slant trailer with a 4' shortwall awhile back. Well, my girlfriend and I are getting ready to go on a trip and for some dang reason it JUST dawned on me that we arnt going to have anywhere to haul hay for the mules. My bed is going to be full of other stuff. So.... I have decided that I better look into other options. I would like to put a roof rack on this trailer to hold some bales of hay. Just curious if anyone has ever built their own rack? I have been trying to look around at purchasing one, but wow they are expensive, and I honestly can't bring myself to spend that kind of money. So.... I will be looking into building my own I guess. If anyone has, do you have any plans for what you've done, etc? Pictures of all trailers with racks would be good too so I can get an idea of the size to build it. I would like it to hold 6 bales or so. Thanks in advance for any help you guys can provide me! Kyle |
      Location: high desert, CA. | Something to remember is; 6 bales of hay weigh about 600 lbs. ( at least my bales), so the roof structure will have to be strong enough to support that weight. Also, when fastening, make sure that there is no "oil canning" action from the roof if it is metal. It seems that constructing a frame out of 1" square aluminum tube stock, and cross bracing, then making support legs, and some kind of fastening or through the roof bolting and bracing, would be a LOT of work, you would need to heliarc and cost is probably going to be pretty steep. I doubt wood would hold up for very long from the vibration and weight.ready made is expensive, but the engineering and construction is already done. Just my 2C's |
Location: Lawrence, Kansas | Our squares that we bale are around 70lbs a piece. 6 is the absolute MOST I would have to take. Normally around 4 for our weekend get aways. |
       Location: western PA | The ends of the rack are supported by the side walls of the trailer, not the roof structure. Our bales typically weight 60 -75#. Having enough support for double the total amount would be a good place to start. If you envision the later inclusion of a generator or water tank, you will have to greatly increase your structural requirements. Unless you have the metal working skills and tools, and can obtain the necesary materials, as was previously stated, you are approaching a difficult task. In addition you will need a ladder; most are fixed and welded to the structures. You may want to consult the talents of a fabrication shop. As is with many projects, there are several ways to build the framework, using various materials and dimensions and welding techniques. I would greatly suggest you look around and find an example that you think would best suit your needs. Photograph it in detail and take a multiitude of measurements. You may be surprised at how much material, it takes to build a fairly simple platform. By copying an existing example that has worked well, the engineering part of the project is greatly reduced. It has to be sturdily constructed. If it fails and dumps hay bales on a car, any injuries or damage that results is your nickel. In the past forums there have been postings of rack systems that can be customised to various applications. They haven't been posted in quite a while, but you may be able to Google them. |
Location: Lawrence, Kansas | Well, I have a fabrication shop on my property. I have a AC/DC Stick welder, a millermatic Mig, access to a tig, cutoff saw, etc. I have moreless a unlimited supply of steel behind my shop thats been saved over the years. It would more than likely be constructed out out of 1-1/2" x 1-1/2" square tubing. I have bolt bins full of stock that would put most hardware/supply stores to shame. So... its safe to say I have PLENTY of material/supplies to achieve this. I am by far very skilled when it comes to fabrication. I guess the purpose of this post was to see if others on here have "made" there own and to see what they have done. I can duplicate just about anything. I just wanted to see some ideas. |
  Location: santa clara, ca | you might as well make it big enough for a water tank and maybe build an enclosed storage areas for high lines, electric fencing and extra tack that you don't use often.don't forget the ladder to get up there..
Edited by adeberti 2012-08-09 12:26 PM
       Location: western PA | Here's some construction ideas: http://www.mrtrailer.com/hayrak.htm http://www.dhmco.com/trailerOptions.asp?pid=13 http://www.coolhorse.com/1873.html http://www.coolhorse.com/index.php/Popular-Trialer-Accessories-Hay-Racks.html |
  Location: Alberta | I've been toying with building a hay rack for years. Fabing the rack is not an issue, my issue is the connection to the trailer. Any thoughts or pictures on that? |
  Location: Pueblo, CO | Just a thought, I was thinking it would be slick if the sides folded flat when you weren't using the rack. It might take too much engineering or be a rattletrap but there would be a aerodynamic advantange, since most people only use the rack occasionally. We had a homemade one on an old trailer we had. It was welded cattle panels and 3/4" or 1" tubing fastened through the fiberglass roof to the roof supports. It held up for the 12 years we had the trailer only using it a handful of times. |
    Location: Topeka Ks | I snapped a few pics of my hay rack for you. When I get to an internet connection I'll upload them . My rack stands off the roof 6" to clear the vents. The front is angled back and sides side are 12" tall. The corners are rolled the same radius of the roof sides. It is bolted to the roof.I owned a Titan and the roof should be plenty strong enough to hold the hay your wanting to haul. I got my hands on an aluminum truck tool box and mounted it up top. Made room in the mangers. Don't forget about a ladder so you can access the roof. |
   Location: North Salem, IN | You might try contacting Titan directly. I had contacted them last year while in the market for a hay rack. Their price was pretty reasonabe for a 5' x 8" aluminum rack. The shipping was the killer with me being in Indiana. They were very helpful and told me their supplier was in Indiana and gave me their contact information. I ended up having to go through a local dealer, as they didn't sell direct to consumers. Regardless, Titan was very helpful, and if you are anywhere close to them, I would at least give them a call and see what they can do for you. |
Location: Lawrence, Kansas | Originally written by justgurn on 2012-08-10 8:25 AM
Pictures I like the looks of yours! Did you buy a kit or build that? |
    Location: Topeka Ks | I bought it from Trisa at Transwest in KC it is made by Cimerron. Ships flat. It was not cheap. |
Location: Lawrence, Kansas | I really like how yours looks, but yeah.... after seeing the price on it I'm gonna have to go a different route. Hopefully the next trailer we buy will have one already on it. In the meantime, I guess I'm gonna have to try and build one. |
| IF I can upload my pictures, this is a hay rack that my husband made, using (I think) 1" square aluminum. He attached it to the structural supports in the sidewall, and the base of the legs rests on the running board. Since the sides aren't closed, I don't think that it impacts our aerodynamics much when it is empty. We haul 2-45 gallon water tanks, and have a deck box permanently mounted there that holds camp stove, stove rack, folding table, chairs, and EZ Up awning. Hubby is asleep, but if you are interested in the details, i.e., the spacing of the aluminum bars, etc, let me know and I'll ask him tomorrow. |
| Sorry, my pictures won't upload. |
Location: Lawrence, Kansas | Originally written by slowrider on 2012-08-12 9:55 PM
Sorry, my pictures won't upload. Darn, would you be willing to email them to me, along with the specs of everything? If so, that would be awsome! My email is millerkyle82@gmail.com |
  Location: Alberta | Slowrider, would you be able to send the pics via email? I can PM you my address.
Very interested in design as well as how he attached it to the trailer.
Thanks in advance! |
 Location: illinois | Slowrider I would also like pictures of hay rack please e-mail at lefebvre@frontiernet.net Thanks |
| a trailer is ace as a result of you'll be able to draw and move for the weekend/week ... however if you're motion on ferries / monetary unit tunnel you may pay further for the trailer.i have a maggiolina on my rack, up high has it's advantages and therefore the tent is up and down in an exceedingly New York minutei guess it extremely depends on what proportion you wish to take a position in tenting ... obtain the most effective and you may forever have folks desperate to obtain good quality kit |
  Location: Alberta | Originally written by laira on 2012-08-16 3:55 AM
a trailer is ace as a result of you'll be able to draw and move for the weekend/week ... however if you're motion on ferries / monetary unit tunnel you may pay further for the trailer.i have a maggiolina on my rack, up high has it's advantages and therefore the tent is up and down in an exceedingly New York minutei guess it extremely depends on what proportion you wish to take a position in tenting ... obtain the most effective and you may forever have folks desperate to obtain good quality kit Anyone want to translate? |
      Location: Rocky Mount N.C. | Originally written by riddenhardputawaywet on 2012-08-16 10:22 AM Originally written by laira on 2012-08-16 3:55 AM
a trailer is ace as a result of you'll be able to draw and move for the weekend/week ... however if you're motion on ferries / monetary unit tunnel you may pay further for the trailer.i have a maggiolina on my rack, up high has it's advantages and therefore the tent is up and down in an exceedingly New York minutei guess it extremely depends on what proportion you wish to take a position in tenting ... obtain the most effective and you may forever have folks desperate to obtain good quality kit Anyone want to translate? http://www.autohomeus.com/ Turn your two horse bumper pull into a two horse bumper pull living quarters...!!! Good way to fix those broken/leaking dry caulk aluminum and cracked/busted fiber glass roofs..!! Just cover up the unwanted seams with a tent!
Edited by retento 2012-08-16 11:00 AM
| A trailer is great in that it enables you to set up camp and leave the vehicle free for exploring, carry more creature comforts and keep the towing vehicle relatively clutter free for passengers. On the other hand, they can reduce your cruising speed on motorways, slightly reduce manoeuvrability and can be a liability if entering the seriously rough stuff. |
| Originally written by laira on 2012-08-25 5:52 AM
A trailer is great in that it enables you to set up camp and leave the vehicle free for exploring, carry more creature comforts and keep the towing vehicle relatively clutter free for passengers. On the other hand, they can reduce your cruising speed on motorways, slightly reduce manoeuvrability and can be a liability if entering the seriously rough stuff. Yes. That's the way I read it and you also mentioned the increased tolls that occur when pulling a trailer. I know I avoid the one toll road I sometimes use if I'm pulling a trailer of any kind. Ferries would be very expensive, too. |
| Is there any chance that you guys can make it so that the Message input text field can be adjusted? I didn't really notice it until today, but it's really small comparatively and makes it difficult to navigate when breaking apart large quotes or editing in multiple quotes. |
| may resuscitate this thread, I'm considering building a roof rack for my Silverado 3H gooseneck with mid tack 30"shortwall.
This rack would be my base; https://www.amazon.com/Universal-Capacity-Aluminum-Enclosed-Trailers/dp/B0CLL1SWJ7/ref=sxin_16_pa_sp_search_thematic_sspa?c=ts&content-id=amzn1.sym.e8834c9f-a716-498d-ab88-40e9d01cd2e7%3Aamzn1.sym.e8834c9f-a716-498d-ab88-40e9d01cd2e7&cv_ct_cx=Truck%2BLadder%2BRacks&keywords=Truck%2BLadder%2BRacks&pd_rd_i=B0CLL1SWJ7&pd_rd_r=5860da88-2e88-40b8-83d9-eff7896cafe3&pd_rd_w=2aaOW&pd_rd_wg=svAQw&pf_rd_p=e8834c9f-a716-498d-ab88-40e9d01cd2e7&pf_rd_r=CJGGQ275B8M4J0ZQV73K&qid=1772045181&s=automotive&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sr=1-1-383bc08e-f3b5-4928-b079-a9607486ab19-spons&ts_id=3097819011&aref=cmQOyfQ5PL&sp_csd=d2lkZ2V0TmFtZT1zcF9zZWFyY2hfdGhlbWF0aWM&th=1
If i
In addition to a hay rack, I thought it would be good to add solar panels in front to charge a LiFe Po4 battery
I plan to use 3 bars as the hay rack base and attach the solar panels between the third and the 4th bar in front of the hay rack .
I like that the rack will bolt to my wall rather than roof, not harming the integrity of the roof. I can cut down the uprights to bring the horizontal bars closer to the roof.
I'll then fabricate the Hay rack basket and attach it to these supports.
thoughts?
Edited by 2Rocky 2026-02-25 12:49 PM
     Location: Tenn/Ala. | To my recollection, no horse trailer mfg. attach any rack to the actual roof. Either attach to the heavy extruded radius that is at the edge, or in the case that isn't possible go down to the wall. |
