Will the manufacturers make recommendations on this?
 Sorry, I have no clue
  I'm thinking if I look at other brands, without loading the horses and driving, is there be a way to know if the axels are placed so that loading the last two stalls would be OK? Once again. If the axles are at the very rear of the trailer, more tongue weight will be introduced. If there is a dressing room ahead of the stalls, there will be more tongue weight. The higher the tongue weight as a percentage of total weight, the more of a loading you can place into the rear of a trailer. This is why most GN trailers can be heavily loaded in the rear and remain stable whilst towing. With a slant load trailer, you can determine the general placement of the axles by comparing them to the stall windows. The butt side windows will be further aft than the head side by about one stall width. If the last stall butt window is against the rear of the trailer, and the rear most axle is directly under that stall, you will end up with significant tongue weight. If a dressing room is added, more tongue weight will be added. This type of trailer will usually allow only rear stall loading. If the axles are located under the middle of the center stall, and there is no large dressing room, loading only the last stall will partially unload the tongue. Try to visualise the axles as being the pivot point of a teeter totter. With the axles centrally located, a 3H BP trailer can be loaded in a balanced configuration with one to three horses. One horse- center stall; 2 horses - one in the front stall, one in the rear. Heaviest in the front. Three horses- heaviest in the center stall, next heaviest in the front, lighest in the rear. This type of loading can result in a 3H trailer having less tongue weight than a 2H ST trailer, and may not need sway and over load mechanicals to correct an over loaded hitch. Once you start looking at the various manufacturers' trailers, you will begin to visualise what results the different constructions will have on the tow vehicles' hitches. Some people believe that the more tongue weight the better. It's better if you want worn tires and suspension components, and want to spend extra money for corrective aids. You can have a dead steady towing experience, with a moderate tongue weight and a balanced load.  Shopping the various brands will enable you to choose what you want. Most sales persons will tell you what you want to hear. Knowing ahead of time what is best for your needs, will make your choices much easier to effect. Look at the many photos in the trailers for sale section. It's an easy way to learn and recognise the differences.
