Evaluate a wooden floor
palomino37
Reg. Mar 2009
Posted 2012-07-16 12:03 PM (#145618)
Subject: Evaluate a wooden floor
How do you evaluate a wooden floor for soundness? I have a 2003 S&H with painted wood floors. I noticed a small soft area near the front. That particular spot is in front of the chest bars so not immediate danger. But I do wonder if it's time to replace the whole thing. This is the original floor. I just wondered what more knowledgeable folks look at when deciding its time to replace.
Posted 2012-07-16 4:14 PM (#145624 - in reply to #145618)
Subject: RE: Evaluate a wooden floor
The easiest way to determine wood rot, is to test the surface with a sharp item. The tip of a knife blade, or the end of a small common screwdriver, pushed into the wood's surface, will detect the density and strength of the wood.
By testing different areas, you will find different results. If the tool tips easily penetrate the wood, then it's rotted and should be changed out. If the wood easily flakes apart and you can quickly dig a small hole, it is beyond its service life. When the surface is hard and not easily penetrated, then it is good for a continued service.
The most critical areas of rot usually occurs wherever the wood is against a frame member, or where attaching hardware affixes the wood in place. The hardware allows fluids to penetrate into the thickness of the wood, having framing directly against the wood, traps fluids and doesn't allow the wood to easily dry out. If the flooring wasn't protected by mats, the horses' shoes will easily erode the wood's surface, opening the grain and quickening the rotting process.
Just poke around a bit and you'll easily discover what's good and not.
Trailer Whisperer
Reg. Jul 2012
Posted 2012-07-16 4:22 PM (#145625 - in reply to #145618)
Hello,
First thing is when in doubt, replace it! You will never forgive yourself if your horse falls through a suspect piece of wood.
Now, what to look for. Large or multiple knot holes in a board can weaken the board especially if located between cross members. Splintering of the wood shows stress and weakening of the woods structure. A soft or spongy feeling board or section of a board is definitely a sign of board fatigue and the need to be replaced.
If you do decide to replace your floor, here is a helpful article http://backyardranch.com/Horse_Trailer_Repair_Part_1.htm
Hope that helps some, good luck!
palomino37
Reg. Mar 2009
Posted 2012-07-16 8:50 PM (#145631 - in reply to #145618)
Thanks for the info. I will check everything as described and start looking for someone to do the work.
Posted 2012-07-17 8:00 PM (#145657 - in reply to #145631)
Originally written by palomino37 on 2012-07-16 8:50 PM
http://www.cwc.ca/index.php/en/design-with-wood/durability/durability-solutions/assessing-decay
cjzarate
Reg. Jul 2012
Posted 2012-07-25 2:01 PM (#145827 - in reply to #145631)
Palomino, I have a 97 Brenderup that needs a new floor. Since B'rup no longer distributes in the U.S. and the Denmark folks aren't exactly falling over themselves to help me out, I am looking around for alternatives. This week, my idea is 3/4 inch thick marine grade plywood. I am attempting to find it in one piece and it has to weight no more than 200 lbs. Pls keep me in the loop as to what you decide to use for your floor. Thanks!
palomino37
Reg. Mar 2009
Posted 2012-07-25 2:09 PM (#145828 - in reply to #145827)
I will stick with the wood floor. I've heard of people using plywood as a short term fix on top of the existing floor, but I wouldn't used it for the long term.
Posted 2012-07-26 10:18 AM (#145865 - in reply to #145618)
1000500100100100252525
this is good information
