Location: Sprinfield, Ohio | Hi, We have a LQ trailer that we are wanting to update. We would like to put in a new ceiling, new lights, new flooring, new backsplashes, ect. What do we need to do to change the lights? Can we use blacksplashes over our current ceiling material that was in the trailer to start with, will it stick and how? We are open for ideas and suggestions. Please help. Thanks26 | |
      Location: high desert, CA. | WOW!So many variables. you could do this as you would for a kitchen remodel, and go for a sheet formica and glue on cover, then a trim router trim, or rip out and go for a really cool replacement with heavy duty counter and back splash like in a home. Lights sjould be just a replace and plug-and-play, flooring is also one where you can go wazoo, and put tile over substrate, or vinyl stip tile over the existing cover. Ceilings you are probably best doing a nice tin cover. or vinyl sheets on hard backing.I would us either Construction adhesive, or silex adhesive. | |
