air conditioning units
memory
Reg. Jul 2007
Posted 2012-07-13 4:05 PM (#145569)
Subject: air conditioning units
What is a broad figure of buying and getting an ac installed on an 8ft shortwall with bracing and electrical in place? Trying to decide if getting it done at the factory for $3,000 is over priced.I will be calling the  RV place 20 miles from here on Monday for a price also.
Other thought is to use a standing air conditioner.
Posted 2012-07-13 7:41 PM (#145571 - in reply to #145569)
Subject: RE: air conditioning units
With the bracing installed and the electrical already in place, THREE THOUSAND DOLLARS is a rediculous price to pay to have an AC unit installed !!!!!!!!!!
The units for your trailer would be in the 13,5000 BTU range, which are currently selling for ~$750 and up. You will need shrouds and extras which will add a couple hundred to that figure. It can be done for ~$1000 depending on the brand and model.
The units come with very good instructions and can be a one hour DIY project, for anyone with a basic understanding and ownership of simple tools; socket set, screw drivers,  etc. Basically the installation consists of four bolts, a weather seal and an electrical plug. A  shroud and garnish finishes it off.
The hardest part is getting it onto the roof, two people or a tractor's front loader works quite well. (aprox 100 lbs). Putting a piece of plywood on the roof before hand, and setting the unit on that, helps a great deal.
Here are some choices:
http://www.campingworld.com/category/air-conditioners/370
memory
Reg. Jul 2007
Posted 2012-07-13 8:04 PM (#145572 - in reply to #145569)
The 3,150.00 did include putting in the electrical box and 30 amp plug. I thought that was very high still. Thanks
CenTex Chris
Reg. Jan 2012
Posted 2012-07-31 11:27 AM (#145971 - in reply to #145569)
Howdy from Texas,
We just bought a new Coleman Mach 3 Power Saver from Camping World for just under $900 and our local mechanic, who is an RV enthusiast, installed it for $150. Hope this helps!
