       Location: western PA | Most lighted assist handles use a bulb and socket for a light source. The acryllic handle distributes the actual lighting. The handle assembly can be disassembled, which allows access to the bulb. Most often the bulb is a common trailer type, which can be replaced with a newer LED upgrade, that will probably last longer than your trailer. |
