Elixir ELX 30 Power Comverter
Zipitude
Posted 2012-04-30 11:52 AM (#143543)
Subject: Elixir ELX 30 Power Comverter
Anybody have any experience with these? I have one in my trailer. I unhooked it to remove the interior and hooked it back up temporarily while redoing the interior. I can't get the 12 volt side to work now. Everything is hooked up as it was before and all the fuses are good. I did the initial install, so I'm sure it's hooked up as it was. Now it wont charge the battery or operate the 12V accessories. I see that these converters are no longer available, so I'm guessing there is a good reason for that!
Posted 2012-04-30 12:03 PM (#143544 - in reply to #143543)
Subject: RE: Elixir ELX 30 Power Comverter
Are you running a single or two wire system? Is the unit properly grounded?
Zipitude
Posted 2012-04-30 12:13 PM (#143545 - in reply to #143543)
Single wire system, and yes it's grounded properly. It's grounded to the chassis.
Zipitude
Posted 2012-04-30 3:57 PM (#143551 - in reply to #143543)
Figured it out! One of the wires for the charger slipped out as I connected it. It still looked as if it was making contact, but in fact was not. hooked it all up again, and all is good. 48
