HELP! Must Replace Gray Tank - Where to find???
barrelrunner66
Reg. Oct 2010
Posted 2012-04-02 2:57 PM (#142736)
Subject: HELP! Must Replace Gray Tank - Where to find???
Our gray water tank has started leaking and upon inspection (are you ready for this??) we have discovered that previous owners CUT THE END OFF, screwed it back together and caulked it. REALLY PEOPLE??? Okay, so anyway, I now have to find a replacement and I'm having NO LUCK. I have taken a ton of pictures of what I'm assuming is some kind of serial/model number. Here is what we have: 2001 Sooner Revolution Tank (gray and black are same): something unidentifiable and H-78 next line on tank: T 1244Gals. 27Imp. Gals 22R.V. Useand the letters SA in what looks like a circle. (if someone can tell me how to attach pictures, I can do that...)Measurements are: L 56-1/2W 24H 4Can anyone help on where to find this? Thanks!Robin
Zipitude
Posted 2012-04-02 3:45 PM (#142738 - in reply to #142736)
Subject: RE: HELP! Must Replace Gray Tank - Where to find???
Try www.jazzsales.com or www.rvsurplus.net
Posted 2012-04-02 4:33 PM (#142739 - in reply to #142736)
If all else fails ...The Tank depot should be able to help... http://www.tank-depot.com/
blackcows
Posted 2012-04-02 7:43 PM (#142743 - in reply to #142736)
100100100100252525
Can you repair it the same way it was repaired before?  I had the same situation on a 2001 exiss and couldn't find a matching tank.  I was able to piece it back togeather with some parts I found at the RV store.  I looked a long time and couldn't find anyting similar to my old tank.
barrelrunner66
Reg. Oct 2010
Posted 2012-04-02 8:10 PM (#142746 - in reply to #142743)
Actually we may just have to patch! I'm not finding anything that matches.....
Posted 2012-04-02 10:43 PM (#142754 - in reply to #142736)
Here's a another supplier that might help. If you have a choice of a polypropylene or ABS tank materials, choose the ABS. It can be altered or repaired using common materials found in big box stores.
The poly tanks are factory welded and have to be used pretty much as they are received. They can be custom ordered with the bung holes and fittings specified by the purchaser. They are not readily repairable.
http://www.plastic-mart.com/category.aspx?cat=34
Judy K
Reg. Dec 2005
Posted 2012-04-03 10:30 AM (#142764 - in reply to #142736)
I had to replace one of our tanks - due to the previous owner not properly winterizing it and since it had an Outlaw conversion - they sent us the exact replacement tanks...we went ahead and replaced both of them at the same time, just to be sure...good luck!  It's a pain in the butt!
