I have checked this site, was listed everytime I asked Google a question. Most impressive. anyway, I have an older Sundowner GN. It was set to a dually when I first bought it. I just bought '06 dually with a 5th wheel hitch already installed. Got the 5th wheel adapter. the trailer sits high in the front. I have a ramp on the trailer. Found the thread in here where there is a GN hitch that goes between the rails on this 5th wheel hitch. My husband claims the difference will not be much, that the nose will come down some but the tilt will still be about the same in the back because of the height of the GN hitch in the truck. Noticed one said on here it was about 8 to 9'' off the bed of truck. so I ask, do I have him (husband) cut off the hitch on trailer to make it come down with the 5th wheel hitch, jack up the trailer or make changes to use GN hitch between rails? Thanks for your time....any advice would be appreciated. got the info for fixing my aux. lighting problem here...putting female plug on battery box, my battery disconnect switch doesn't work. thanks! |
