 Location: Grayson Co. Texas | My LQ fridge works fine on electric, but when I switch it to LP for traveling it fires right up and the needle goes to green but as soon as I let off the igniter it starts going down and won't stay in the green. Any ideas from some of y'all? Thanks |
   Location: Coconut Creek, FL | open up the panel on the outside of the trailer and clean off the carbon on the pipe. YOu can tap the pipe lightly to get other debris to break off and then clean out the inside of the area with a hair dryer or blower. You will be amazed at the amount of crud that accumulates. I've also had wasps build their nests in their twice which blocked the area. I open it up and clean it out once a month during camping season. |
 Location: Grayson Co. Texas | I'll try it..thanks for the help |
 Location: Boyd, MN 56218 | I didn't ask the question, but needed the answer. Thanks so much. |
