Location: Austin, TX | Hi! I am brand new to this forum. Looking to purchase my first LQ 3H trailer, yay! Husband works for 4 Wheel Parts & I currently tow with a 2005 4x4 Chevy Duramax w/a 6 inch lift kit & 35 inch tires. This truck is all setup with gears and tows great (boat, car hauler, 3H BP, enclosed 30 ft BP trailer, etc). So, I don't want to lower the truck. My questions are: 1. Is anyone towing their GN LQ with a lifted truck? 2. Are there any particular brands of GN LQ that ride higher off the ground, so I'd have more clearance between the bed of the truck & the gooseneck. I did use the search function, but I didn't see any other threads on this subject or I wasn't using the correct words.I don't want to dent the bed of the truck and a lot of places I currently tow to are down unpaved, bumpy roads. I've also looked into replacing the bed of the truck with an after market aluminum/steel flat bed, which would eliminate the problem completely. However, those are kind of pricey.Any advice is appreciated!Thank you,Jasmin | |
 Location: Illinois | Short answer, you won't be able to pull a GN trailer with the factory bed. If there is a dealer near you go there and back under a trailer then lower the trailer till the coupler is about 3-4 inches above the floor of the bed IF you have clearance. | |
        Location: Vermont | Originally written by jasmintx on 2012-03-14 8:59 AM
Lifted trucks really do not lose towing capacity if the right equipment is installed...BUT....
larger tires affect everything. Say your truck has 410 gears with 265-70-17 tires(a tire at 31 inches tall) and you lift your truck and install 35-36" tall tires.
What you have just done is changed your differential gear ratio to about a 3.08 which is not a gear for towing compared to a stock sized tire with the 410 ratio differential.
Also the driveline angle has to be considered when towing with a lifted truck(you need the proper drop on your hitch). Braking is really not affected much, but it is affected some.
towing a heavy load with a lifted truck is okay if everything has been considered.
And you'll never get the proper clearance of the bed rails for a GN short of bolcking up the trailer substatially | |
       Location: western PA | Oversized tires and lift kits, effect a negative change in almost anything a truck is designed to do. It changes the center of gravity, increases the pinion angles whilst reducing the U joints' longevity. As Paul said, the effected gear ratios are changed, along with the braking, handling and ride. What is the load rating of the oversized tires? A flat bed would be your only recourse to haul a GN trailer. This would not be an ideal tow vehicle under any circumstances. | |
