| Please share your experience and expertise. Is a bumper pull available? I tow with a 2500hd Silverado, but have only done BP to date, not a frequent traveler, so is GN a must? Why?New to the forum, so if this has already been discussed, please point me to a thread - I did a search but did not find the info. | |
      Location: Rocky Mount N.C. | Ths is probably the nicest 2+1 gooseneck I've seen... http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=363360 Most all of the mfg's are building a 2+1 gooseneck, not seen a BP yet. I have a Gore two horse BP with a side ramp and dressing room. Gore, Hawk, Blueridge, Sundowner, Adam, as well as others build two horse BP's with side ramp and DR. Not enough room in the side ramp area for that third horse, if there was room, it would be too heavy on the BP hitch. My tongue weighs better than 900# loaded with two horses, and all our gear in the tack room and a few items in the side ramp area.... Probably should have gone with a gooseneck, but I wanted someting I could pull with a 2500 Yukon or Suburban, Avalanch or 3/4 ton pickup...
  Location: Zionsville, Indiana | Retento is right, there are several manufacturers that make nice two horse straight load bumper pulls with side rams. I wouldn't call it a 2+1 however, as there is not room for a third horse. You should be able to buy a new 2+1 gooseneck in the $24,000 to $28,000 range, including side ramp, rear ramp, box stall divider, dressing room, etc. If the divider wall is on a slant (some are slant, some are straight), pay attention to which side the side ramp is on. If the wall is at a slant, the ramp needs to be on the passenger side so that you could run a golf cart of other vehicle up the side ramp and not run into the wall. Also pay attention to the width of the side ramp. This could be important depending on what you plan to load up that ramp. | |
        Location: Vermont | Originally written by hobbyhorse on 2012-02-15 2:40 PM
A REAL 2+1 bumper pull would be tough to engineer NOT to overload the maximum tongue weight | |
