  Location: Western US | Hello, kind of new to the board...I hope I get my terminology right.I ran my Onan gen 2 weeks ago, with zero trouble. Went to start it on Sunday, and it acted like it was going to start right up...seemed to run fine for about 1 beat, stopped. I tried starting it again, same result. After that, couldn't get it to do a thing. I can hear it trying, but never actually starts. So how can I tell where my problem is? I realize it can be any number of things...moisture in the lines, clogged fuel filter or pump, or I guess even a clog in the line.... The place I normally take can't get it in for a month, and I don't want to wait that long. And husband is not mechanically inclined in ANY way :) Not sure if it matters, generator is on the roof, fuel tank is in the rear tack. Thanks! |
   Location: North Salem, IN | First place to check would be the fuel pump. Make sure you are getting fuel up to the generator. Check the simple things first and go from there. |
  Location: Western US | Okay...sounds good, but stupid question....how do I check them, and what am I looking for. I think I have two....I can see one in my rear tack, and I think there's another up in the Gen compartment. |
| Check oil first, if low it will shutoff quickly after starting. |
   Location: North Salem, IN | Do you have a switch to turn on power to the fuel pump or does it run automaticly when generator is switched on? Either way, you can disconnect the fuel line anywhere after the pump and switch it on and see if you have fuel. You would want to do this in a manner to allow the fuel coming from the pump to be captured. (put another hose on the line and capture in a drain pan or gas can) If your switch is in the living quarters, it would be a good idiea to have a friend help you since you can't be in 2 places at once. If the pump doesn't run, make sure the fuse is good and you have power to the pump. Also check to be sure it is grounded well. There should be a fuel filter in the line as well. You'll want check it aslo to be sure it isn't clogged up. |
  Location: Western US | Pump comes on automatically....Thanks for the tips, I'll try them, as soon as I can get a helper :) |
  Location: Western US | Okay....test results: Took off fuel filter, which is up by generator...no fuel comes through line when I prime or try to start. Then disconnected fuel line from fuel pump, which is just above the tank in the tack room; left all the wiring alone. Still no fuel when primed or started. So can the pump be clogged, and if so, is there a way to unclog it, without replacing it? The pump and filter were replaced almost two years ago, and the lines cleared out as well. Thanks for the hand-holding! |
  Location: Western US | Re-read your post re: the pump. Where is the fuse, in the pump itself? |
   Location: North Salem, IN | I wouldn't know were the fuse is located but I would guess it would be near the switch. Can you check with a test light to see if you have power to the fuel pump? That would eliminate looking for the fuse. If no power, make sure you have power to the switch. If you do have power at the pump, make sure the ground wire is making good contact. If it is, then more than likely you have a bad fuel pump. |
  Location: Western US | This may have gone beyond my skill level, but I'll give it a shot.....I'm assuming there is power to the switch, because the light on it blinks, if I prime it, I can hear a sound that I normally always hear when I prime it.So next step is to test the power to the pump itself. Can I test that with the little tool you can test your trailer plug with, or do I need a more powerful tester? There are two wires that come out of the top of the pump, one black, one white. These connect with some kind of little connector to the wires coming from the trailer. I would imagine I "unplug" those, and test them?Thanks... |
   Location: North Salem, IN | You can test it with a simple test light that looks like an ice pick with a light in the handle and wire with a ground clamp on the end of it. You don't need any fancy tools. |
        Location: North Carolina | Looking at your pic... I see the wire seems to be discolored. Is that true? And it looks like the inlet side of the pump was sealed with teflon tape. Improper use of teflon tape to seal threads might cause your pump to get clogged. Always leave the first full thread clear of tape. Otherwise, the mating thread will cut the tape loose to clog something. |
  Location: Western US | There's a black and a white wire exiting the pump...I think the semi-clear connector that is connecting the white wire to the red wire is making it look discolored. But in looking at it closer to answer your question, there seems to be three different splices between the pump, and the wires that seem to be coming from the trailer. So I guess there could be a problem at any of those junctions as well. I'm in the process of trying to get the "butt-connectors" off so I can test the wires...but either I'm just not strong enough, or you need a special tool. Though about just cutting the wire, but I should probably disconnect the batteries if I'm going to do that, right? It looks like both in, and out sides have the teflon tape....when you say leave the first full thread clear...is that the first thread that goes in (so now you can't see it), or do you mean the last thread, the one you'd see first if you started unscrewing it? Also thinking that if there are three splices, maybe I should eliminate those when I put the new pump on, so that there is only one connection.... |
  Location: Western US | Was able to determine I'm definitely getting power to the fuel pump. Didn't get the right pump today so going back in the morning to try a different one. The one that is being replaced isn't made any more. Thanks so much for all the help so far, at least I've been able to troubleshoot things enough to get to this point! :) |
        Location: North Carolina | Originally written by AJS on 2012-02-16 1:35 PM It looks like both in, and out sides have the teflon tape....when you say leave the first full thread clear...is that the first thread that goes in (so now you can't see it), or do you mean the last thread, the one you'd see first if you started unscrewing it? The first thread of the male portion going into (so now you can't see it), the female portion should be clear of the tape. As the fittings are screwed together, any tape over the fitting end will be cut free to clog the pump internals. or anything else ! ! Always do this when using tape... no matter which direction of flow in the fitting. You don't want pieces of tape in any system. |
  Location: Western US | Good info, thank you!....do I need to use it at all? I was going to, just because someone had already done it...is one of those cases where less is more? |
        Location: Vermont | Originally written by AJS on 2012-02-15 12:04 PM
Which Onan generator do you have?
Which model carter fuel pump do you have?
Depending on which carter fuel pump...does your system have a pressure regulator involved?
What is the actual lift height that the pump is having to deal with?
  Location: Western US | I have the Onan MicroQuiet 4000. The fuel pump WAS a Carter P61145S. It's 90" from the floor (where the bottom of the tank rests) to the ceiling. The pump is positioned 34" up from the floor. Once the fuel gets to the roof, it makes a turn, and travels roughly 8' to the gen itself. I don't know of a pressure regulator on the system... |
  Location: Shawnee, Oklahoma | This may not apply to you, but we have encountered a lot of generator problems with customers who use gas with ethanol. We only use pure gas in everything. |
  Location: Western US | Thank you....I try to avoid ethanol, but I haven't been able to locate non-ethanol fuel in my area. :( |
       Location: western PA | Snowmobile and marine outfitters sell non ethanol diluted fuel. |
    Location: Rayne, LA | I have used star tron fuel additive with success so far. |
        Location: Vermont | Originally written by AJS on 2012-02-17 10:27 AM<BR><BR>I have the Onan MicroQuiet 4000. The fuel pump WAS a Carter P61145S. It's 90" from the floor (where the bottom of the tank rests) to the ceiling. The pump is positioned 34" up from the floor. Once the fuel gets to the roof, it makes a turn, and travels roughly 8' to the gen itself. I don't know of a pressure regulator on the system... Well that pump should be pumping at least 4psi...if it isn't then lift could be an issue...I'm assuming you have checked your fuel filter and it is NOT gunked up.Finally if you are using ethanol-laced gas...make sure you are using Marine Formula Sta-bil,it seems to their best for ethanol
Edited by PaulChristenson 2012-02-18 11:56 PM
 Location: Bloomington, IL. | This will work I think Delphi FD0002 electric fuel pump. Should be able to get at local napa store.
    Location: Valentine, NE | Didn't read all the comments, but I had a like system. After several boast fuel pumps in a few years, I put an in line filter just before the pump (between it and the fuel tank) and that solved the problem--never had to replace boast pump again. Just an idea. Good luck! |
  Location: Western US | Still working on this...thanks for the tips regarding fuel and the stab-il-izers. Actually placing a filter prior to the pump makes a lot of sense. I purchased the replacement pump from napa, looks just like the photo from DLM-10, but it's a Carter not a Delphi. However, it seems to be designed for 3/8" fuel lines, and I have 1/4". I realize I could use the little hose ends they include, and then add some adapters to connect it to my existing lines, but it sure seems like I'm asking for more problems by doing that....Monday, I'm going to try to get my hands on a Cummins pump, the one that Outlaw put in, in the first place.This is starting to feel like a soap opera... :) |
