A LITTLE OFF TOPIC
Posted 2012-02-14 3:18 PM (#140947)
Subject: A LITTLE OFF TOPIC
 I know I'm stretching the trailer maintenance issue whilst posting in this forum, but this thread can be applicable to LQ interiors. Has anyone used the hardener Tractor Supply sells for their oil based paints with polyurethane oil based finishes?
I've used many dozens of gallons of poly finishes, mostly by spraying applications. When it's cold, I commonly use Japan Drier and acetone as a thinner, and had very good results. But with these cooler temperatures, the drying rate is over twelve hours, and a couple of days to cure.
Recently I used the TS oil based Valspar "tractor" paint, on some kitchen metal cabinets I slavaged, repainted and installed in my shop. Using the TS hardener, the paint dried quickly in the very cool area. The directions said it would also work on poly products. I've never used this additive before, and so far I'm pleased with the results.
Has anyone else had any experience with this product? I will make some test panels to see about its drying abilities, but I'm also concerned if it will change any of the poly's physical attributes. Thanks
farmbabe
Posted 2012-02-14 5:24 PM (#140962 - in reply to #140947)
Subject: RE: A LITTLE OFF TOPIC
1000500100100
Thats way above my pay grade. I just like things to be pretty. Good luck!
Phoresic
Reg. May 2010
Posted 2012-02-14 5:33 PM (#140964 - in reply to #140947)
500
LOL. Nothing you could say would be off topic:).  I wish I had an answer but don't.  I will read the thread with interest, though.
Posted 2012-02-15 10:42 PM (#141038 - in reply to #140947)
1000500100100100252525
let us know how it works
Posted 2012-02-27 8:26 AM (#141488 - in reply to #140947)
An update. My trials of trying to use Tractors Supply paint hardener in an oil based poly varnish, ended up being a failure. When used with their Valspar oil based paint it was a complete success, considerably reducing drying times.
When added to the varnish, it actually increased the drying times by almost double the original amount. I had hoped that this would be the magic elixir, the chemical that would alleviate the last negative for using the oil/poly varnishes; IE long drying times.
So if you're going to use their paint, buy the hardener. If you are varnishing your latest project, don't waste your time and money with the additive. Japan drier helps a bit, using acetone as a thinner helps the varnish to flash more quickly, if you need it to. Otherwise, when you spray, thin with the paint thinner as recommended by the manufacturer.
terri s
Posted 2012-02-27 9:58 AM (#141493 - in reply to #140962)
500100100100
Originally written by farmbabe on 2012-02-14 5:24 PM
Looking for the "like" button!
terri s
Posted 2012-02-27 9:59 AM (#141494 - in reply to #140962)
500100100100
terri s
Posted 2012-02-27 10:01 AM (#141495 - in reply to #140947)
500100100100
Farmbabe: Thats way above my pay grade. I just like things to be pretty. Good luck!
Searching for the "like" button!
terri s
Posted 2012-02-27 10:02 AM (#141496 - in reply to #140947)
500100100100
Sorry about the triple post! Wasn't loading properly on this end.
Phoresic
Reg. May 2010
Posted 2012-02-27 11:00 AM (#141498 - in reply to #140947)
500
Thanks for the follow up Gard.  Great information as always.
Posted 2012-02-28 9:23 PM (#141542 - in reply to #140947)
thank you for the information sorry it did not work for you
