to block or not to block.......
malinois
Reg. Dec 2011
Posted 2012-01-26 6:33 PM (#140322)
Subject: to block or not to block.......
I was wondering if those of you who do a lot of hauling on dirt/mtn roads with your LQ trailers have blocked axles? Or are most brands of LQ trailers high enough that the tanks underneath are not apt to get busted.
Any pros...cons to blocking axles?
I appreciate any input you may have!
Thanks!
gonzo1066
Reg. Oct 2010
Posted 2012-01-26 11:23 PM (#140326 - in reply to #140322)
Subject: RE: to block or not to block.......
I blocked my New Platinum 3" more and have NO regrets at all.   We do a fair amount of back country travel and the stock level was not adequate. You just have to find a shop that is capable of doing the job correctly..
malinois
Reg. Dec 2011
Posted 2012-01-27 10:36 AM (#140338 - in reply to #140322)
thank you! I also read some of the past posts on blocking and I do think I will have it done.
ponytammy
Posted 2012-01-27 12:45 PM (#140339 - in reply to #140338)
500100100252525
We had to block our Elite LQ 2 inches in order to make it ride level with new Dodge Dually. Horses load and back-out quietly just like they did before the blocking. If you have plumbing or grey/black water tanks sitting low, then might be a good idea if you are taking through rough, unlevel terrain.
crowleysridgegirl
Reg. Apr 2005
Posted 2012-01-27 1:20 PM (#140340 - in reply to #140322)
2000500100
We blocked our Exiss for the same reason and there have been a couple of instances that we have really been glad that we did,or,we'd come home sans tanks facing a big repair bill.
malinois
Reg. Dec 2011
Posted 2012-01-27 5:55 PM (#140348 - in reply to #140322)
Thanks! Yes, it's those rough roads and the underneath tanks that concerned me.
I am sure I will be happy with the block....horses will just have to learn to pick their feet up a few more inches!
Spin Doctor
Reg. Nov 2008
Posted 2012-01-29 8:48 PM (#140392 - in reply to #140322)
One of the top LQ companies recommends putting a skid plate under tanks instead of blocking axles if the only reason is to protect tanks. Due to that added floor height after blocking, they say this works better. Price is about that same either way.
But I am sure, everyone's motivations are different.
Good luck!
malinois
Reg. Dec 2011
Posted 2012-01-29 9:51 PM (#140395 - in reply to #140322)
Thank you for that info. I did consider the skid plates, but really didn't know which might be better and thought the extra height might not be a bad idea considering our mtn roads here.
Any real negatives to blocking the axles besides a higher step for the horses?
Spin Doctor
Reg. Nov 2008
Posted 2012-01-30 4:13 PM (#140422 - in reply to #140322)
Horses are an issue as mentioned. But, also, please take in account the number of times you jump in and out of the trailer also. We talked about blocking ours, but that top saddle rack is already a pain to get a roping saddle on. Another 2", and the wife would not unsaddle my horses.... Just stayed with a flatbed on our new puller so life is good!
cajunmuleman
Reg. Oct 2011
Posted 2012-01-30 5:19 PM (#140424 - in reply to #140322)
What about wind resistance ( MPG ) and cross winds? Would this be a concern?
Posted 2012-01-30 10:15 PM (#140431 - in reply to #140322)
The MPG doesn't usually change. Mostly the rear of the trailer is being elevated, the frontal area has not been altered. The center of gravity will be slightly raised, which if you were racing, might be a problem. The side's sail area remains the same, side winds and oncoming trucks' vortices, will effect little change.
You shouldn't have any concerns about the blocking. It has been accomplished by many owners who have pulled safetly many miles. The largest concern with higher lifts is perhaps a ramp to ease loading, or as mentioned, limited access to the rear tack areas. The handling of the trailer is minimally changed.
crowleysridgegirl
Reg. Apr 2005
Posted 2012-01-30 11:17 PM (#140434 - in reply to #140395)
2000500100
Anything that can drag tanks off could do some damage to a skid plate,too,I would think.I don't want anything near mine.Our horses are trail horses,anyway,stepping up in the trailer isn't that big a deal to them.Backing out the first couple of times was,unless you have a pony,it'll be OK after they get used to it and it doesn't take long.Just had to take it slow.
RTSmith
Posted 2012-01-31 9:14 AM (#140437 - in reply to #140322)
Most of the "skid plates" we have seen can be handy to protect against road debris, etc. tearing up a tank or valves.
But to protect one from a true high center or grounding, the plate will have to be strong enough to fully support the weight of the trailer while it is acting as a sled. I don't believe most people are going to tolerate the weight/expense penalty that such a structure would require.
A lot of the damage we see is where the driver drops one side of the trailer's wheels off of the road, and it settles down on the belly. The next step usually involves literally dragging it back up on the road with the truck. The tanks, valves, and slide out steps are all casualties. I'm not sure that a plate would be practical solution for this.
Just my thoughts.
RTSmith
malinois
Reg. Dec 2011
Posted 2012-01-31 10:37 AM (#140440 - in reply to #140322)
I REALLY appreciate all the good info on this subject. Very helpful.
Thank you!!!!
jdzaharia
Reg. Apr 2006
Posted 2012-01-31 3:44 PM (#140452 - in reply to #140322)
1001001001002525
Good thread and good discussion.
When you all blocked your axles, did you just leave the tire/wheel size the same? How about the fenders? I know function comes before form, but my tires and fenders would look silly with 3-inch blocks.
Michaelj
Reg. Jan 2012
Posted 2012-01-31 4:13 PM (#140454 - in reply to #140322)
The problem is that the trailer manf. people have dropped the nose of the trl, in order to allow more head room in the bed area, which closes the gap between the Bed on the truck and the bottom of the Trailier. Then on top of that the Truck maker extended the height of the rails up and or more off road equipment that closed the gap as well. If the Trailer people would go back to the regular height, that would save the expensive blocking needed on the trailers! It's not cheap...
