Help w/ towing capacity
tollertwins
Reg. Nov 2011
Posted 2011-11-08 7:25 AM (#138785)
Subject: Help w/ towing capacity
I have a 2000 Tahoe w/ a 5.4L engine and a WDH on it. I have been towing a brenderup -which tows easy. I have had MOST of this trailer rebuilt at one time or another.
However, last nite we found out that we have an issue w/our ramp. Combine that w/ my new horse not liking ramps much, and the fact that we were planning on buying a 3h next summer when we move to Wa. and we're thinking about cutting to the chase and buying a 3h now.
However, I'm not sure what is safe to pull w/ this vehicle - we had ALSO been planning on buying a 250 size deisel truck. However, I just can't swing that easily right now.
Have been looking at the Shadow 3h stock/combo type trailers.
Pulling initially would be just 1 not very big horse, and in Houston (e.g. FLAT!).
If anybody has info on stuff like hitch weights on these that would be helpful too...nobody seems to have specs online for this stuff.
Posted 2011-11-08 8:24 AM (#138787 - in reply to #138785)
Subject: RE: Help w/ towing capacity
One advantage of a 3H SL BP trailer, is that by placing various numbers of horses in different stalls, it's possible to better balance the load. This results with the trailer's axles carrying most of the weight and the pin or tongue weight being more nominal.
This is only attainable by choosing a trailer that has axle placements nearer to the center of the frame. The best arrangement will have the middle stall centered over the axles. Here's a few trailers with this configuration:
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=353541
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=353252
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=353206
Trailers with axles placed more to the rear of the frame, will place a higher loading on the tongue and hitch. With horses loaded and a frontal tack area full, the tongue weights can be substantial. They will require auxilliary weight distribution hitches to maintain a proper level towing vehicle. Some examples of this configuration are:
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=350947
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=326349
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=353578
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=353631
A mid sized vehicle can safely tow a properly set up 3H BP trailer. We did it for several years using an Expedition.
Posted 2011-11-08 10:01 AM (#138788 - in reply to #138785)
Originally written by tollertwins on 2011-11-08 7:25 AM
Your ground may be FLAT...but you can experience some severe crosswinds in TX...even a tradition 2 horse bumper pull with a dressing room will be a step up in the experience level that there is a trailer behind your TAHOE...
christymae
Reg. Nov 2011
Posted 2011-11-09 11:30 AM (#138819 - in reply to #138785)
This site has a calculator you can use to determine a safe towing weight. It even includes a "safety margin". Most of the entries needed can be found in your user manual or the sticker/plate on your driver's side door. You don't have to fill in every entry, either, but more entries=more accurate results!http://changingears.com/rv-sec-calc-trailer-weight-tt.shtmlSorry I don't know how to make it a link :(
Edited by christymae 2011-11-09 11:32 AM
Posted 2011-11-09 11:48 AM (#138821 - in reply to #138785)
Edited by retento 2011-11-09 11:49 AM
