Location: California | I have a 3h GN trailer and a Silverado 2500HD Duramax. We just got a pop-up GN hitch installed on the truck, but when we tried to hook up, I noticed that the truck bed is about 1" (if that) shorter than our gooseneck receiver (?) Again, not sure how to describe it but when we're dropping the trailer on the ball, it isn't sitting snuggly and dropping down properly. The gooseneck receiver (?) on the trailer needs to be lowered. I didn't want to strip the bolts and am going to have my neighbor (a trailer repairman) take a look but was wondering how exactly to describe this to him. It might be an easy fix, but I didn't want to get messing with it and make matters worse. We pulled it with an older Chevy flatbed and it was perfect height, so knowing how to raise or lower the gooseneck 'receiver' might be beneficial. I wasn't sure how to search for this, so if its a repeat question, I apologize. I'm not exactly trailer savvy so any information would be appreciated. |
      Location: Ottawa, Illinois 61350 | Your trailer probably either has one or two "set screws" or bolts with lock nuts on them. If it is the older style coupler, this is probably all that holds the coupler from traveling up and down (vertically). Simply loosen the lock nuts first, than put your wrench on the head of the bolt and loosen them next. If your hitch has been in this same position for a long time, it may be stuck, and require a smack with a hammer to break it loose. When you get the coupler to the disired position, retighten the set screws and lock nuts. If your coupler is the newer stye with a steel pin thru holes in both the coupler and the sleeve that it fits into; chances are it will have only one "set screw" to loosen like the old style coupler. Simply loosen the set screw, and than take the safety clip from the steel pin, remove the pin, and slide the coupler to the next hole setting to change the height of the coupler. Re-nsert the pin and clip, and than retighten the set screw and lock nut in it's new position. That should do it. |
