Fresh water tank
To Much Trouble
Reg. Dec 2009
Posted 2011-10-04 11:28 AM (#138043)
Subject: Fresh water tank
IS there any way to keep the water fresh smelling and useable in your horse trailer...I absolutely hate the smell of the fresh water..and NEVER do I use it for cooking or drinking..just clean up. I do not let water sit in the tank..it is drained after each trip..and flushed out well before the next use..  But really what can a person do to make the water better?  is it the water? the tank? are there additives one can put in the tank ?  possibly a different kind of tank ? filter system.( I would so invest in a filter system)  Ideas / thoughts are greatly appreciated
paysonw
Reg. Aug 2010
Posted 2011-10-04 12:10 PM (#138044 - in reply to #138043)
Subject: RE: Fresh water tank
We get some additive at the farm supply or Big Box and it helps with the odor.  I believe I put about an ounce in each time I fill the tank (25 or 30 gal tank).
To Much Trouble
Reg. Dec 2009
Posted 2011-10-04 2:03 PM (#138046 - in reply to #138044)
got a name for the stuff ?   Im thinking of trying a sink top filter system w/ the filter cartriages...the kind you change the filter every so often...
Posted 2011-10-04 4:11 PM (#138048 - in reply to #138043)
http://www.billydump.com/3r/3rhome.htm
trot-on
Reg. Dec 2009
Posted 2011-10-04 5:21 PM (#138051 - in reply to #138043)
Have you done a good cleaning with bleach water? At least once a year I put bleach, and fill tank, and let it soak for the day, then dump it, and refill and dump.
Posted 2011-10-04 9:47 PM (#138057 - in reply to #138043)
You could add one of these to your nozzle... http://www.purwater.com/pur-products/?gclid=CI7_k7TD0KsCFcjb4AodHCF...
To Much Trouble
Reg. Dec 2009
Posted 2011-10-05 8:53 AM (#138066 - in reply to #138043)
LOL  ya I clean out the fresh water tank several times a yr..well, basically everytime I am preparin to take a trip..it gets cleaned and flushed...and a really good cleaning and flushing coming out of "winterizing"...
jim bob
Reg. Jan 2008
Posted 2011-10-05 10:36 AM (#138067 - in reply to #138043)
A bottle of Real Lemon added to a tank will help the odor a bunch.
To Much Trouble
Reg. Dec 2009
Posted 2011-10-05 3:07 PM (#138076 - in reply to #138043)
Thanks jimbob...question:  do you add to tank after use,or  to water being used ?  and if it is after use, do you just leave it in tank and flush before fill ?
