What screws for ceiling and walls
Terrye
Reg. Nov 2010
Posted 2011-09-02 12:26 PM (#137194)
Subject: What screws for ceiling and walls
Hi everyone,
I am insulating and should be installing my furring strips shortly.
What kind of screws should i use?
It is a 2006 cimmeraon if that makes a difference?
Thanks,
Terry
Posted 2011-09-02 3:25 PM (#137197 - in reply to #137194)
Subject: RE: What screws for ceiling and walls
I left the screw heads exposed on my ceiling. I figured the heads would get wet from condensation in the winter. I was right... Glad I used stainless steel screws.
Posted 2011-09-03 8:19 AM (#137211 - in reply to #137194)
Stainless steel pan head sheet metal screws work well attaching wood to aluminum. Do not use steel screws into an aluminum construction. Steel screws are OK when using on steel trailers. Predrill any holes.
Bulk amounts can be purchased from marine suppliers such as Jamestown Dist. Many big box stores only sell packages of 5 ea or so at a high unit cost.
RidnClyde
Reg. Jun 2012
Posted 2012-06-06 8:14 PM (#144624 - in reply to #137194)
If I'm using 1x2 framing on 2x2 aluminum supports, what size stainless steel sheet metal screws would you recommend?  #10 x 2" or is that length a waste?
Also, does the stainless steel number matter?  I'm seeing a lot of SS 321, SS 316, etc. on boat sites related to using screws with aluminum and don't understand it.
Posted 2012-06-06 10:33 PM (#144630 - in reply to #144624)
The screw tips should fully penetrate the metal studs, until the full diamteter of the screw is used. Most 1 x 2 framimg is 3/4 " thick or slightly less. I would think that a screw of  1 1/4" length would be sufficient. If you use a flat or round head screw in soft Pine or Spruce, the heads will usually pull flush with the wood without having to use a counter sink.
The 316 numbers are for stainless hardware specifically used in a salt water environment, and are not necessary for a wood to aluminum interior project. The less expensive and more readily available 18-8 hardware will work quite well.
Depending on the screw spacing, you may be able to use #8 screws instead of 10's.
RidnClyde
Reg. Jun 2012
Posted 2012-06-07 6:27 AM (#144637 - in reply to #137194)
Thanks Gard, that's very helpful. :-)
wowlijetgold
Reg. Jun 2012
Posted 2012-06-12 9:51 PM (#144761 - in reply to #137194)
I think success has no rules, but you can learn a lot from failure. -----------------------------RS Gold|Cheap Runescape Gold|Cheap RS Gold
wowlijetgold
Reg. Jun 2012
Posted 2012-06-12 9:56 PM (#144763 - in reply to #137194)
