Posted 2011-08-23 6:45 PM (#136919) Subject: air conditioner for trailer - coleman mach III?
It seems that I'm finally moving forward on my little 4' weekend package. I'm not sure how committed I am to an ac but I probably do need one.....I'm always more concerned with cold than hot :). Anyway, I looked a CL and saw this one. I do have a reinforced 14 x 14 space for one. Would this be the right one for a 4' weekend package. Right now I have a Honda 2000 EU generator.What questions should I ask?Thanks for any suggestions.
Posted 2011-08-23 6:49 PM (#136920 - in reply to #136919) Subject: RE: air conditioner for trailer - coleman mach III?
this is the ad:This is a Coleman Mach III Air Conditioner Upper unit. Model# 86338876.This unit is used, but is very, very clean and is fully functional and works perfectly. It is new condition with no problems or blemishes. I guarantee this unit to work.It dos not have the inside ceiling package, if you do not already have it you will need topurchase that seperatley. It uses any 8330, 9330, 7330B751 or 7530B75 ceiling assembly. Fits in a standard 14" x 14" vent hole.This ac has the new style cover/shroud that covers the fins on the back so you will avoid hail damage!Newer unit, has not seen much use. Hurry and call me as this one is so nice...it will not stick around long. You will not be dissapointed, this unit could easily pass for new.
Posted 2011-08-23 10:49 PM (#136931 - in reply to #136919) Subject: RE: air conditioner for trailer - coleman mach III?
Posts: 2962 Location: North Carolina
To run the a/c with your generator you'll have to buy another eu2000 and a cord to connect the two together. (Honda also makes a eu2000 companion that has the 30 amp outlet built in. Still need a special cord to connect the two)
