Goose Neck adjustment
sidelock
Posted 2011-07-24 11:53 PM (#136046)
Subject: Goose Neck adjustment
Should a goose neck with tandem axles  be level when hooked up to the tow vehicle or should the front  be slightely higher than the back ?
Posted 2011-07-25 12:42 AM (#136047 - in reply to #136046)
Subject: RE: Goose Neck adjustment
We run our GN trailers 4" high at the front while empty. This results in no bed interference problems. Our Timbrens and factory overload springs then contact the stops after ~4" of travel, which provides a comfortable ride and some suspension travel when loaded.
Jeepplr
Reg. Oct 2007
Posted 2011-07-25 3:58 AM (#136051 - in reply to #136046)
I try to keep it as level as I can, as I run the propane fridge and it needs to be level.
wyndancer
Reg. Apr 2007
Posted 2011-07-25 11:07 AM (#136056 - in reply to #136046)
Level when loaded.
