Brisk Air ?
griffsmom
Reg. Oct 2009
Posted 2011-06-30 8:50 AM (#135297)
Subject: Brisk Air ?
I have a question regarding an air conditioner (Duo-Therm Brisk Air) that I took off our truck camper and gave to a friend for their horse trailer. It had sat unused for about 2 years and when they installed it, it fired right up, but just wasn't cooling like it used to. They went and had it re-charged and it cools some but not like it used to. Does anybody have an idea of why it wouldn't be cooling like it should. I told them to make sure that they plugged it into a outlet that could handle the draw, and try that too. Just a shot in the dark of what could be wrong with it. Thanks
griffsmom
Reg. Oct 2009
Posted 2011-06-30 9:05 AM (#135300 - in reply to #135297)
Subject: RE: Brisk Air ?
I'm not sure on the re-charge option. I am wondering if it is the compressor that is bad. You can hear the compressor actually kicking on but not making a difference. Just another thought.
gonzo1066
Reg. Oct 2010
Posted 2011-06-30 9:17 PM (#135309 - in reply to #135297)
Was the unit stored flat??   This used to be a huge deal with all refrigeration units.  When stored incorrectly the compressor (I think) looses the oil.
griffsmom
Reg. Oct 2009
Posted 2011-07-01 7:44 AM (#135314 - in reply to #135297)
No it was on the camper while not being used. I called an rv place and they forwarded me on to another business, so I am just waiting for them to call. Hopefully its not to much to fix.
Bluerose2001
Reg. Aug 2010
Posted 2011-07-01 10:35 AM (#135323 - in reply to #135314)
Subject: Brisk Air
First does the compressor seem to kick on and off a lot? Might have a thermal overload sensor going bad. Need to time and see how long the compressor actually runs. I would by a little digital thermometer and just observe it over a few hours. If the compressor kicks in and runs continuously for 10-15 minutes it is probably operating fine. If the compressor kicks on and off every three minutes something needs diagnosed. Could be a capacitor going bad- when it does there will be no compressor kicking on and just the fan running. The thermostat might need replacing (or checking for shorts). Good luck!
ponytammy
Posted 2011-07-01 12:32 PM (#135327 - in reply to #135297)
500100100252525
Just a thought... since the A/C came off a camper which is small space the BTUs might not be enough to cool a larger LQ area, especially one that is not inuslated. Might want to check the BTU to see if it is adequate to cool the LQ trailer.
Posted 2011-07-01 1:42 PM (#135329 - in reply to #135297)
Some numbers to ponder....
Dometic
