Is widening a trailer feasible?
rsc
Reg. May 2011
Posted 2011-05-01 11:05 PM (#133746)
Subject: Is widening a trailer feasible?
I have a 32' stock trailer that I need to have the floor redone on. It's a 1979 model, so it's pretty heavy and solid. I was wondering if it would be feasible to have the trailer widened. It's currently 6' wide, and I'd like to make it 7', or at least 6.5' wide if possible. I know I'd have to replace a lot of stuff on it to do this, but a lot of the stuff that would need to be replaced is stuff I'll have to do sooner or later (probably sooner) anyway, so I'm thinking if I can go ahead and do it all at once and get it widened as well, I may as well.Could this work? I have a guy who is going to redo the floor for me, but I don't want to make myself sound like a total retard by asking him this if it's not doable.
Posted 2011-05-01 11:38 PM (#133747 - in reply to #133746)
Subject: RE: Is widening a trailer feasible?
Anything made of metal can be built, modified, repaired or replaced. The bottom line is the cost and the quality of the changes. I can't imagine how replacing your trailer with a wider model, wouldn't be the best course of action.
Posted 2011-05-02 8:24 AM (#133750 - in reply to #133746)
As Gard said, Anything can be modified. But you need to weigh the cost.
The labor to cut down your existing trailer and then basically totally rebuild it. will be much more than the labor to build a new trailer.  many of your compenets will need to be replaced or modifed.  For example. Your axles are probably the width of your current trailer.  You would need to buy new wider axles, And probably heavier axles since the rebuilt trailer will weigh more and be able to carry more.
I personally think it makes financial sense to just shop for and buy a new trailer that is wider.  If you have emotional attachments maybe it's worth the cost to rebuild it.
hornet
Posted 2011-05-02 9:38 AM (#133751 - in reply to #133746)
Now hold on guys, all he needs to do is sprinkle some fairy dust on the trailer and really really believe.
Edited by hornet 2011-05-02 9:39 AM
dawnb
Posted 2011-05-02 4:38 PM (#133764 - in reply to #133751)
Hey hornet then if I plant a money tree I will start getting money in a couple of years?
hornet
Posted 2011-05-02 8:11 PM (#133771 - in reply to #133764)
The problem I've read on money trees are they have an extremely long gestation period before they start bearing bills and the suffer a devastation disease called taxhitess. In the end most trees die before bearing.
Posted 2011-05-02 10:02 PM (#133774 - in reply to #133746)
1000500100100100252525
would widening the trailer change the regulation on it ?
Posted 2011-05-03 7:10 AM (#133778 - in reply to #133774)
Originally written by loveduffy on 2011-05-02 10:02 PM
For one thing, the registration would have to be changed to "home-built"... But to answer the OP's question...NOT really feasible...because the floor supports would all have to be widened as well as the multiple roof seams that would be created...
Edited by PaulChristenson 2011-05-03 7:14 AM
Southernboy
Reg. Oct 2007
Posted 2011-05-03 8:05 AM (#133781 - in reply to #133746)
How difficult (expensive) is it to shorten a trailer?
Posted 2011-05-03 10:52 AM (#133782 - in reply to #133746)
About $2.00. If you have a chaulk line and a buddy in your local fire and rescue squad, for a half a gallon of gas you can make your trailer as short as you want.
All you need is one of these:
http://www.toolfetch.com/cut-off-saws-965169301.shtml
dallyup
Reg. Mar 2011
Posted 2011-05-03 10:54 AM (#133783 - in reply to #133746)
really? it doesn't take a rocket scientist to figure out the problems with this question.
 The only way this would work, is to tear it completley down to the frame and rebuild from the bottom up, not very ecconmical, don't you think?
pinkmouse
Reg. Jan 2009
Posted 2011-05-03 12:14 PM (#133785 - in reply to #133746)
 With all this talk of widening and shortening, I was thinking about raising the roof about 12" on mine - how easy would that be??  LOL
Posted 2011-05-03 6:04 PM (#133792 - in reply to #133785)
Originally written by pinkmouse on 2011-05-03 12:14 PM
Definitely easier than widening it...
Posted 2011-05-03 9:36 PM (#133797 - in reply to #133746)
very funny
paysonw
Reg. Aug 2010
Posted 2011-05-04 2:34 PM (#133818 - in reply to #133792)
Originally written by PaulChristenson on 2011-05-03 6:04 PM
And much,much easier than lowering the floor 12"!!!
Edited by paysonw 2011-05-04 2:35 PM
robdnorm
Posted 2011-05-04 10:30 PM (#133836 - in reply to #133746)
500
I had a friend that actualy raised her trailer height 8 inches to accomodate her draft horses.  It was a major undertaking to say the least.
genebob
Reg. Nov 2007
Posted 2011-05-04 11:25 PM (#133837 - in reply to #133746)
I've got a friend who raised the roof on his stock trailer 12" 25 years ago. It was actually fairly easy. Cut off uprights at the top rail, weld on 12" of tubing to upright and replace roof and weld together. Trailer is still in use today.
